DAC difference
Sep 14, 2021 at 5:54 AM Post #346 of 357
gregorio
If you do learn to listen, ...
That's the thing though, most people don't learn to listen. In fact, the vast majority of audiophiles don't even seem to understand the basics of hearing and listening or the role of perception, let alone actually learn to listen.
If you put some miles on the road and get the chance to hear what some very creative members have developed in their quest to sonic perfection, you'll find there's a lot of ways to that end.
I have listened to what "some very creative audiophiles have developed in their quest to sonic perfection". Generally, what they've achieved is a long way from sonic perfection because they haven't learned to listen and they have no idea what "sonic perfection" is!
[1] Some of us need to control the metallurgy of the wire and solder used on our ICs. [2] To that end, yeah there are differences if it's important to you.
1. Sure but then that conflicts with your first point, because if you do learn to listen, then there's no difference!
2. To what end? If the end is sonic perfection (and one learns to listen), then "No" there are no differences. If on the other hand, the "end" and what's "important to you" is visual appearance, status symbol, keeping up with the fashion of audiophile marketing or anything other than audible sonic performance, then "Yes" there are many differences.
[1] My enjoyment of recorded music improved a lot when I changed from the DAC in an Oppo BDP 105 to a Dangerous Convert-2 converter, (both via USB). [2] The improvement in resolution was spectacular.
1. That's entirely possible.
2. That's not possible, unless one of the units was defective.
[1] Would be interested in any input as to the possible technological reasons for this difference.
[2] EDIT: Resolution was even better when bypassing the volume control on the Convert, but only to a relatively slight extent.
1. There are no technological reasons for that difference, you're looking in the wrong area. The areas to look for those differences are user error and/or perception error.
2. That's possible, if it's a digital volume control and if, for example, you are lowering it by a significant amount and compensating with much higher amp gain. However, this would come under "user error"; poor gain staging.
G
Sep 14, 2021 at 11:01 AM Post #347 of 357
PointyFox
Here you can hear the difference between DACs.
Holo May Dac _(Z Reviews)_ The💎Crown💎Jewel💎of💎Excess
Didn't he NOT hear a difference? The comments section is filled with people calling him a pleb and telling him he's just not sophisticated enough to hear the difference and comparing DACs to fine wine, Ferrari tires, etc. :smirk:
Thank you! So it seems you need this expensive player to hear the difference?
Zeos has used some Pi-whatever crap.
Of course not. A signal is a signal. A DAC is either going to degrade it or it's not.
Oct 24, 2021 at 1:37 PM Post #349 of 357
theveterans
Santa Rosa, Laguna, Philippines
I have bought a 4xTDA1387 true-multibit NOS DAC. It sounds totally different than my delta-sigma DACs.
That should not come to a surprise. NOS in itself with any true NOS DAC would sound totally different (in both presentation and tonality). Even in DS DACs with NOS filter selection (aka super slow roll-off) would sound slightly different than Linear Phase fast roll-off filter of the same DAC usually in presentation where the super slow roll off would collapse soundstage with smoother edges while the fast roll-off would sound more tactile but with rougher edges. The filter differences aren't just limited to 15KHz and up, there are low level distortions from the super slow filter along the lower audible frequency range that can contribute to the sonic differences heard between DAC filters of the same DAC
Oct 24, 2021 at 6:52 PM Post #350 of 357
bigshot
Hollywood USA
You could probably make a modern DAC sound like an old NOS DAC with a little EQ.
Oct 24, 2021 at 8:21 PM Post #351 of 357
redrol
New Mexico
In terms of DAC -> Line out -> amplifier I can't hear any differences with anything modern. Go figure. The rest of the equation matters is my opinion. The DAC just need to be decent.
Oct 24, 2021 at 8:32 PM Post #352 of 357
bigshot
Hollywood USA
My experience is the same.
Oct 25, 2021 at 1:54 AM Post #353 of 357
gregorio
All bets are off when it comes to NOS DACs. While some are half decent and don’t sound any different, others, namely the filterless designs, are effectively broken and can sound different.
Not having a reconstruction filter obviously means the waveform is not reconstructed. In addition to the HF roll-off others have mentioned, which can start as low as 2kHz, distortion is much higher, quantisation error is much higher, timing is inaccurate and the chances of inducing IMD are much higher due to ultrasonic “images”. All of which can result in significant audible differences with these types of NOS DACs. Why anyone would deliberately not comply with Nyquist/Shannon requirements is beyond me but the audiophile world can often be a nutty place!
G
Oct 25, 2021 at 1:58 AM Post #354 of 357
bigshot
Hollywood USA
I only know about the very early CD players that had an audible high end rolloff. They actually make DACs with no filter at all? That is nuts.
Oct 25, 2021 at 2:15 AM Post #355 of 357
gregorio
I’m not sure if filterless NOS DACs are available any more and if it’s only restricted to DIYers these days but a few years ago it was a bit of a thing in certain audiophile circles. And “Yes”, it was/is nuts!
G
Oct 25, 2021 at 4:01 AM Post #357 of 357
bigshot
Hollywood USA
Defective by design! Yow. How dumb do they think their customers are? no... don't answer that. it's like selling a car without a transmission and telling the buyer that the power is more direct and pure without gears.
