Cyrus SoundKey portable DAC
Mar 17, 2017 at 4:55 AM Post #121 of 185
I've been using my Cyrus for my laptop and it really is a wonderful little DAC for the kickstarter price I paid, even at full price it will put others to shame.
Probably won't get the coverage it deserves until Cyrus give some freebies to certain reviewers who will then decide its fate!!!
Mar 17, 2017 at 6:46 AM Post #122 of 185
It's Cryrusiously good!
Mar 18, 2017 at 10:55 AM Post #124 of 185
I'd rather use the word Cyrusiously, unless you meant it makes you cry of joy. 8:wink:
Yes sorry you're correct. I got a bit carried away there:grin:
Mar 19, 2017 at 6:40 PM Post #125 of 185
I backed this project too but still waiting for my dac. In comments on Kickstarter I read about dissastified backers because of crumbling case. Did you have a similar experience?
Mar 19, 2017 at 6:50 PM Post #126 of 185
No it seems solidly made to me. The only issue you might have is with some popping and clicks when listening on a mobile device. Might be a power issue as there are no issues on the laptop.
Mar 19, 2017 at 8:04 PM Post #128 of 185
I only get it occasionally between tracks and very occasionally when I'm performing another task on my phone.
Honestly not too bothersome and any drawbacks are far out weighed by the frankly superb sound offered by this tiny device. Currently using my HD25s
They've only sounded better through a Mojo and then not by much. It really opens up headphones nicely and sounds so pure and crystal clear yet refined.
Everyone really should have received theirs by now though but it'll be worth the wait
Mar 20, 2017 at 7:14 AM Post #130 of 185
I'll skip it.
With things like the K1 and the Fulla 2 and the Centrance Dacport slim
Good for you
Be aware those devices weigh 2or 3 times as much. An important consideration for a truly mobile device. I also fail to believe any of those can sound better than the Cyrus
Each to their own....
Mar 21, 2017 at 10:02 AM Post #132 of 185
As I also own a K1, I can tell you the SoundKey listening experience is better than K1.
Thanks that's no surprise.
It's Fiio this and Schiit that on here. The forums often seems like a huge marketing tool for those brands. I tire of the automatic endorsements in answer to every recommendation. They are worshipped whilst others are ignored.
Mar 31, 2017 at 2:57 PM Post #134 of 185
Mar 31, 2017 at 3:06 PM Post #135 of 185
