Cypher Labs Theorem 720
Discussion in 'Portable Headphone Amps' started by drsheep, Sep 3, 2013.
14 15 16 17 18 19 20 21 22 23
25 26 27 28 29 30 31
  1. Ultrainferno
    How would you see that? DAP vs idevice dac with built in amp.
    I have both but have never used them in the same setup
  2. singleended58
    I have listened to my Theorem 720 paired with iPhone 4S (CAN is Hifiman 400 with Norm cables RSA balanced). The sound almost similar to this combination Cavalli Liquid Carbon amp (new one) + Chord Hugo DAC + Apple MAC air source + Audeze LCD can except the latter has more body.
  3. iDesign
    Has anyone ever compared the CypherLabs 720, ALO International+, and CEntrance HiFi-M8? How would these amplifiers be ranked in 1st, 2nd, and 3rd place strictly based on performance and technical specs (not size, weight, and battery life etc.)?
  4. singleended58
    1) CL Theorem 720
    2) ALO Internstional +
    3) Centrance M8
  5. wairx
    Is close the ALO International to Theorem 720 with headphones which need high power?
  6. czy6412
    How was the sound using Theorem 720 pairing with TH900
  7. kh600rr
    Tried it at a show once, paired very well.love my 720
  8. midnightwalker
    Apple and Orange...but for sound quality and portability, I would vote for the AK240 but for power and p/p, I would be on 720 side.
  9. midnightwalker
    Amazing !!! [​IMG]
  10. tunes
    I would like to try the theorem with my WA 7 tube amp and bypass the WA 7's DAC. I need a good analogue cable from the Theorem Line out to the WA7 RCA input L and R jacks. Any suggestions????
  11. tunes
    I am trying to choose a line out cable 3.5mm (1/8”) analog to RCA male for using another tube amp with
    the Theorem. So far the Audioquest Forrest and Blue Jeans seem good and close in price. Anyone feel that one is better than the other??
  12. georgelai57
    After owning the Theorem for a while now I'm ready to explore balanced. It is surprising how little info I can get via Google so what better than here? Can someone show me a pic of how the cable from my headphones end at the Theorem? Is it better to get a complete new cable for my custom IEMs or are there adapters I can use. Photos would be most useful. Thanks in advance.
  13. lukeap69
    This is what I'm using to adapt my 4-pin XLR balanced cable to use on the Theorem 720.
    georgelai57 likes this.
  14. fiascogarcia
    You can use an adapter as long as your current cable is balanced.  If it is a single ended non-balanced TRS jack, you would need to re-terminate your cable or replace it with a cable with the correct balanced jack for your Theorem.
  15. georgelai57
    Thanks
