CX-300 problems
post-7660981
Thread Starter
Post #1 of 8
silentshou
I'm on a low budget so I bought some cheap Sennheiser CX300-B, but i'm trying them out right now and there seems to be some problems...
The left side seems "lacking" compared to the right... I tested the earphones with a solid sine oscillator at 50~100Hz, panned completely to one side then the other, and the left side definitely sounds... weaker. Then I switched sides and tested the left plug on my right ear... same results.
Is this normal with new products (albeit cheap)? Would it get better once I burn it in?
Oh and another thing that i noticed is that if i accidentally flick the cable, it creates a bassy kick-drum-like sound, but only when it's plugged in. And yes, the sound is actually coming out of the earbuds... I held the wire into a loop and at arm's length, under my desk. If it's plugged in when i do that, it makes a noise, but not when i try it unplugged.
Is that... normal?
post-7660997
Post #3 of 8
DaBomb77766
Where did you buy these from?  There are a ton of fakes out there, and fakes have pretty sub-par build quality.
post-7661002
Post #4 of 8
silentshou
Amazon.com
But I bought them new and it seems to come in the right packaging?
post-7661515
Post #5 of 8
DaBomb77766
Amazon.com
Fakes can look pretty real.  What store did you get them from, and how much did you pay for them?  I guess that if you got them directly from Amazon they shouldn't be fake, but if you got them from one of the other sellers there, there's a good chance it is.
Anyway, what's happening isn't normal.  If they are in fact real, then they are defective.  If they're fake, then you should get a refund.  Either way, that shouldn't be happening.
post-7662847
Post #6 of 8
Hannover, Germany
Hannover, Germany
Age
75
There are a lot of fakes out there - beware. Only buy from an authorized dealer. Check with your local Sennheiser office to verify the integrity of a dealer before buying. Sales through a non-authorized channel are not typically eligible for warranty, especially if they are counterfeit.
Click here to view a list of non-authorized Sennheiser dealers
Sennheiser Stay updated on Sennheiser at their sponsor profile on Head-Fi.
https://www.facebook.com/SennheiserUSA https://twitter.com/SennheiserUSA http://www.instagram.com/sennheiser https://sennheiser.com/
post-7663424
Post #7 of 8
silentshou
I bought it from a vendor who's "fulfilled by Amazon." I left a negative feedback and the vendor offered to send a replacement. Now I feel kinda bad... maybe I should've contact them directly first...
post-7663901
Post #8 of 8
dbdynsty25
Well yeah...that's normally how a bad transaction goes.  You contact them to see if they'll replace them first...if no, then bad feedback.  That sucks.  You probably just have a defective pair from the factory and how is any vendor supposed to know that when they are selling sealed product direct from Senn?
