Cut headphone cable
May 20, 2004 at 12:24 AM Thread Starter Post #1 of 4
D-EJ915
He...or is it she...is a......Headphoneus Supremus
My friend's cat cut his D22's headphone cable (the 2 leads going to the left cup) and I was wondering if I should just solder the two back together...would that be a bad idea? thanks
May 20, 2004 at 1:55 AM Post #4 of 4
Sal
You might was well give it a try. Either that or send the headphones in for repair.
Be warned, soldering headphone wire can be tricky because they use an odd type of cotton/wire for flexibility that doesn't solder very well. It can be done but don't expect it to be as easy as soldering a DIY amp.
My dog chewed some headphone cables and even though I was able to splice them back together, I was never totally happy with them afterwards and had to buy new ones. Nothing wrong with the sound mind you, I just couldn't get over that they weren't 100% anymore.
