davidcotton
X-CANs and HDAMs
- Jun 23, 2001
thx!
my customs are acrylic and I've been wearing them for five days. when I had my impressions done, I got closed mouth impressions and I clenched my jaw a bit too hard because I was nervous. i'm mainly concerned about comfort, I mostly listen at home, with the iems in my ears for up to 8 hours a day. at the moment, the canal portions on both sides have a dull ache after about half an hour. it gets pretty unbearable after a while. the left canal also feels a bit to long, the seal breaks often and the cymba portion doesn't really fit well unless I press the iem in until the tip hurts. if I were to get a refit, do you have any tips as to what I should do if I redo my ear impressions?
Not Piotr, but here's some tips that I've picked up from him and on headfi. As ever ymmv and I'm sure Piotr will chime in at some point
Use a bite block, and relax the jaw. Even though it's called a bite block the idea is to have it positioned in the mouth to keep the jaws opened.
Did your audiologist know about ciems or were they used to doing hearing aids only? If the former you should be good to go discussing the problems with them and showing them the instructions from the 64 audio site. If the latter then you really need to stress the differences between the hearing aid and the ciem for impressions. This I think is where I've been having issues and it's only now that I've changed audiologists that I have come to realize that.
Maybe contact 64audio and see if there are any audiologists in your area that they could recommend?
Good luck in getting them sorted out, I know all too well the frustation of not getting a decent fit from customs.
