crinacle's IEM FR measurement database
post-13703339
Post #406 of 1,322
castleofargh
Sound Science Forum Moderator
hi everybody. subbed, thanks to the op and other contributors for this amazing thread. nice collection of measurements, very good job, congrats!
i started to measure FR of IEMs last year summer, using iMM-6 + tube and mobile AudioTools. since then, was trying to improve my rig till february; i had to stop to concentrate in other tasks, not related to audio.
now i've read this thread, would like to share my rig evolution, together with some comparing graphs, because it has many coincidences with crinacle's one. hope somebody finds it interesting.
1- iMM-6 + silicone tube. Mobile (input & output) + AudioTools (software).
my mobile input had a terrible bass and treble roll-off, and the output had about 17Ω (http://www.head-fi.org/t/800208/#post_13041235), so had to change the input to my pc soundcard (http://www.head-fi.org/t/800208/#post_13019304), output to a neutral DAC with output impedance lower than 1Ω (like iBasso D14 http://www.head-fi.org/t/800208/#post_12995932, or JDS C5D).
new software was needed. chose REW.
the nozzle of many IEMs wasn't wide enough to be sealed by the tube, so i had to find a good sealing tip to use with every iem. found that one of those used with stetoclips was a good solution.
2- iMM-6 + silicone tube + tip. PC soundcard (input) + iBassoD14 (output DAC) + REW.
compared to pro rigs' measurements, like Tyll's one, found many differences: lows and highs roll-off, different amplitude and location (frequency) of mid and highs peaks, etc.
tried to use the calibration file which came with iMM-6 (it was a joke), and played with the distance from the IEM's nozzle to the mic. that distance resulted to be very important; but even the best distance try showed too many differences to consider a huge effort in calibration of the whole rig.
suspected that the diy "coupler" was responsible of the main differences, so tried to make an stainless steel coupler instead, using some vape gear i had around.
3- iMM-6 + DIY SS "coupler".
a bit better, but still many differences. the mic fixation to the coupler by using bluetac was not stable enough, and the distance issue was there too.
so decided to invest into a chinese iec711 coupler, made by aluminum and other metals, which came with a mic, without any calibration. and also purchased another chinese iec711 coupler after, made by stainless steel and other metals, to check the consistency of these chinese couplers.
4- "cheap" mic + 711 couplers.
couplers:
mic which came with aluminum coupler (6mm-1/4"- mic, like imm-06, fixed to a 12mm-1/2"- threaded cillindrical case, to be screwed into the coupler):
found that lows and mids (till 5 or 6KHz) were more accurate this way. but from 5-6KHz, the peaks were better located (frequency) in my old rig (iMM-6 + DIY SS "coupler"), despite of their bigger highs roll-off after 10KHz.
this graph show the difference between them (the similar curves correspond to new rig, rolling tips and varying depth insertion). used VSonic GR07 classic ed.
to get better results in highs, i tried to fit the iMM-6 into the 711 couplers, because suspected that the cheap mic was responsible of the frequency offset's mess.
and compared mics and 711 couplers.
5- iMM-6 + 711 couplers.
to fit the iMM-6 (6mm mic) into the couplers (12mm threaded), used a thick silicone o-ring and bluetac.
and here are the compare graphs of GR07 classic ed, using both 711 couplers, iMM-6 and the cheap mic.
C1 is the aluminum coupler; C2 is the stainless steel one.
M1 is iMM-6; M2 is the cheap mic which came with the alu coupler.
C1 + iMM-6 (different tips and insertion depth):
C2 + cheapMic (different tips and insertion depth):
C1 vs C2, + cheapMic (to compare couplers):
slight amplitude differences at the 8-9KHz peak and at the 11- 12KHz dip. maybe the o-ring I added into C2 to get extra isolation, did vary some distances (my bad, i should repeat the measurement without that o-ring); or that is the slight difference between couplers, I don't know. anyway, minimal difference.
C1, iMM-6 vs cheapMic (to compare mics):
note the dip of the cheap mic in lows (40Hz centered), and its frequencies offset (from 9.5KHz to 8.5KHz); highs roll-off in iMM-6 (and some lows roll-off, but under 20Hz).
now, measuring Piston 3.
C1 + iMM-6 (different insertion depth):
C1 + iMM-6 vs C2 + cheapMic
again similar differences, due to the mics, mainly. 9.5Khz -> 8.5KHz offset in the cheap one, and highs roll-off in iMM-6.
conclusions:
agreeing crinacle's comments, i think that an iec711 coupler helps to get closer to the real thing, and so does the mic.
having a iec711 coupler, i'd prefer using iMM-6 (easier to calibrate the highs roll-off) rather than the cheapMic (very difficult to fix that frequency offset).
but the insertion of iMM-6 into the coupler (using o-ring+bluetac) is not very stable, i guess. i'd probably cut the cillindrical threaded case of the cheap mic (about half size), insert iMM-6 into that case, adding some bluetac, and screw the result into the coupler.
i guess this rig, after some calibration (not so heavy), would satisfy my needs and expectations so far, and would be portable (laptop + dac + rig).
6- Chinese "pro" rig (iec711 coupler + precision mic + preamplifier + stand) + low noise and distortion input (E-MU 0404).
my PC soundcard inputs has excessive noise and distortion to be used to measure other parameters different to frequency response. so i purchased a low noise and distortion one: E-MU 0404.
after spending in two iec711 couplers and this interface, thought i should try a "pro" calibrated mic. so purchased a chinese one, AWA14424D (calibration provided in a piece of paper, like GRAS ones), very very fragile.. which came mounted into a new iec711 coupler (AWA6162) to minimize the risk of damaging the mic while being mounted, and together with an appropriated preamplifier (AWA14604C) and an stand/base. Ouch, ouch, ouch, this did hurt my wallet badly.
now i have two spare iec711 couplers (if anyone is interested, pm me).
i've finished my other tasks, six months later, so i'll restart with audio again.
here are some pics of the new rig:
(another parameter, wrote in chinese -can't translate it-, says 76% at the end of the paper -wasn't caught by the cam-)
ok but which one is the right measurement? :stuck_out_tongue_winking_eye:
do you get significant variations in say THD+N or simply noise between the couplers? I'm itching for some slightly less lowfi measurement rig, like lowfi+(crazy, I know). so I'm really interested in the range of actually affordable gear for a little more than simple FR. but I wonder if money and efforts won't just be drowned under how bad everything else still is. or that I'm doing all this right next to my noisy laptop fans and the street.
Wetware collates like nothing else. Procedure and associated kit can muck that up. Many work tirelessly to not hear differences and succeed.
*starts chanting the list of subjective biases*
Reactions: hakuzen
post-13703562
Post #408 of 1,322
DanWiggins
Member of the Trade: periodic audio
Get a Clio Pocket for around $600. I can share with you a 3D print model for an IEC 60318-4-like coupler. Slide the coupler on the end of the mic, put your IEM in the other side, and measure away!
post-13703624
Post #409 of 1,322
castleofargh
thank you for trying to help, but we're clearly not at the same level. that's why I asked the other cool buddy who started from 30$ mic and went up instead of you. I can relate to that ^_^. I get maybe 3 IEMs in my hands per year(aside from the dozen of little crap IEMs I own for no clear reason), so it really wouldn't be reasonable to buy a Clio Pocket. I'm an absolute amateur with slightly above average curiosity and not much money.
but it does look like a really cool toy. I usually drool looking at the QA401 trying to make up an excuse to justify getting one to measure 2 DACs and half an amp per decade. now I'll be having fantasy arguments about why I need a Clio.
post-13703722
Post #410 of 1,322
hakuzen
i had to stop with audio on february, so haven't tried the e-mu nor the last rig. so no THD+N nor noise measurements yet. will do and post.
:o2smile: i don't know which is the right measurement (and probably i'll never know). by the moment, i'm using measurements from people which are using expensive pro gear, as a reference.
the nearest one from those i was able to try, was 711 coupler + iMM-6.
there are too many parameters (physic and not so physic) involved.. the result will always be relative. but the most interesting things in this world are relative; they have infinite combinations, they respond to science in some ways but also escape to it (because actual science is not complex enough to know the exact thing, or because there are "parameters" which aren't related to space/time coordinates nor cause/effect). in these cases, i like to try science the further i can (limited by my knowledge, decreasing learning ability, and by my wallet), as an start point; then, i'll remain open to any other possibilities, knowing that reaching the real thing is impossible. but i'm enjoying the trip a lot; although the goal is impossible, the journey is worth it ..and funny.
edit: my first stage is to get some consistency without having to spend a huge effort in calibration (using "relative" references, by the way)
post-13703808
Post #411 of 1,322
castleofargh
thanks, I was just being an ugly troll about which was the right measurement. but the rest does interest me. including whatever noise/disto you get between the different mics. I realize that the input and output gears will also play a part, but just to get one snapshot of one situation could inspire me to get the same or to stick to playing Macgyver to get the very best of a very mediocre rig.
@cricri, sorry for always taking your topic off road.
Reactions: hakuzen
post-13704100
Post #412 of 1,322
Sinusoid
Member of the Trade: Audio Dealer
EU
EU
Hello measurement gurus!
I hope you can advise me on doing my own little measurements. I was happily measuring away my in-ears only until I realised I had another measurement mic to compare. Since the two mics resulted in very different graphs I borrowed yet another pair of professional measurement microphones and they all result in completely different graphs, rendering the whole process, well, pointless. I'll add a pic of the same in-ear (VE8) measured by 4 different mics. I use Smaart software and there is a tight-sealing flexible silicone tube I use to connect the tip of the mic to the in-ear. Signal used is pink noise, that should read flat on the Smaart RTA window. I'm including the pink noise line (pink in color :)) to show the response curve of just the electronics. Anyone with an idea why all the mics give such different results, especially in the bottom end are most welcome to comment!
post-13704242
Post #413 of 1,322
crinacle
Member of the Trade: In-Ear Fidelity
SG
SG
Website
crinacle.com
Again, no worries about that. This is probably the only thread in this subforum that such technical talk be tolerated, and even appreciated.
Reactions: dongster
post-13704245
Post #414 of 1,322
crinacle
SG
SG
Website
crinacle.com
I'm guessing it's not the mic, but the coupler that's causing the massive differences. The bass rolloffs look typical of a lack of seal to me.
post-13704318
Post #415 of 1,322
crinacle
SG
SG
Website
crinacle.com
A teaser for what's to come:
Just need to tweak the compensation file slightly and the entire database can finally be shifted to approximate the 711/318 standard.
post-13704355
Post #416 of 1,322
DanWiggins
Well, note with the CLIO you can make electrical measurements as well, with a different input adapter (replace the mic with some alligator clips). And really, short of a really pro rig I think you can get interesting data, but anything that is really representative of potential performance takes a nice calibrated microphone with low noise, a very good mic preamp and A/D converter, some nice software, a VERY quiet (acoustically and electrically) enivronment, and patience.
post-13704357
Post #417 of 1,322
DanWiggins
Seal and size. Your coupler is MUCH too small, and you're probably leaking all around the place. Solve the leak with Silly Putty or Blue Tack; either will seal nicely and peel off cleanly without leaving a residue.
Also note that mics need to be calibrated with a given preamplifier; drive voltage will affect not just sensitivity but frequency response, as will the loading of the mic preamp. You'll get different results if you don't calibrate the entire input chain.
post-13704370
Post #418 of 1,322
castleofargh
did you try to align the response on the certificate graph to see how much variation you get?
that 9-10khz clear bump almost as high as the 3khz, is something I get on the er4sr when I use the comply tips.
post-13704422
Post #419 of 1,322
datranz
I'm curious if my thoughts are correct, our ears and brains can differentiate sounds in milliseconds, and it's how we are able to have spacious cues, i.e. Doppler effects or echo in a large room. So we correlate that to iems soundstage to sound decaying at some region in the fr? Can we be able to somehow interpreted from the Csd graphs?
post-13704425
Post #420 of 1,322
crinacle
SG
SG
Website
crinacle.com
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
