Creative Super X-Fi headphone holography
10 11 12 13 14 15 16 17 18 19
  1. phoenixdogfan
    I would bet the unit is designed to work with any neutral headphones (as defined by the Harman curve), which means a whole host of high end phones ought to work just fine--especially if they're eq'd.
  2. limjohn5
    I' ve tested SXFI amp with EP660, Aurvana SE, HD598, HD650/HD6XX, Emu Teak. All of their main sound signature to my ears sounds the same. (Although their sound signature is the same but there are some inherent difference because of the headphones itself, like closed back is different from open back, the details/resolution that the headphone is able to create are different, decay speed, soundstage etc) What I think creative SXFI app did when you select the profile is most likely modify the sound signature to emulate ELAC speakers that they are modeling after. So just get a headphone model that is listed in their SXFI app list and you will be able to get the same ELAC speaker sound signature. If there is a specific sound signature that you prefer, you can try different headphone model in the app and see whether any of it fits your taste and if you want to be more specific, you can use the EQ in the app to further customized to your taste and the settings will all be saved in the SXFI amp which is a very nice touch. So It also means that you do not need to buy expensive headphones to enjoy the SXFI experience.
  3. limjohn5
  4. phoenixdogfan
    If it only had headtracking!
  5. limjohn5
    An amp with head tracking?
    Btw i think head tracking is unnecessary because I am looking straight at the screen 99.9% of the time so unless you are laying down on your bed or couch and would like the music to play from your feet or from your side, it is not necessary for head tracking.
  6. Nerdybeng
    Indeed the amp won't know. You have to use the app to select the headphone profile. The app will connect to their servers to combine your ear structure and selected headphones to come up with a sound profile that gets loaded onto the amp. I think the app can store more than one profile, but only one gets loaded onto the amp at any point in time. So one would be somewhat handicapped without the app, and only be able to turn the SXFi effect on or off, but won't be able to change headphone profile.
    Using the same pair of headphones, I selected different headphone profiles. The sound changes, but I haven't tested whether this is in any way related to impedance. The difference in sound between most headphone profiles are typically less obvious than turning SXFi on and off. However, to get the most out of the amp, it is still important to select the correct headphone profile, so an external AMP won't really solve the problem.
  7. Vader2k
    I asked them via chat back on 11-09-18 and this is what they told me:
    "As dated 19 Oct 2018, these are the certified headphones/In-Ear available:
    • Aurvana Live! (Super X-Fi certified)
    • Aurvana Live! 2 (Super X-Fi certified)
    • Aurvana SE (Super X-Fi certified)
    • Aurvana Trio (Super X-Fi certified)
    • EP-660 (Super X-Fi certified)
    • Outlier Black (Super X-Fi certified)
    • EMU Teak (Super X-Fi certified)
    • EMU Walnut (Super X-Fi certified)
    And while the headphones/In-Ear below are not certified, they are available for selection on the SXFI APP:
    • AKG K701
    • Beats Solo3
    • BeatsX
    • Audio Technica ATH-AD700
    • Audio Technica WS55X
    • Beyerdynamic DT880
    • Beyerdynamic DT990
    • Bose QC35 II
    • Jaybird X3
    • Sennheiser HD569
    • Sennheiser HD598
    • Sennheiser HD650
    • Sennheiser HD800
    • Sony MDR-XB950N1
    • V-Moda Crossfade M-80
    Kindly note that the SXFI AMP will work on all headphones and earphones, but works best with headphones or earphones that are Super X-Fi certified."
    Hope this helps!
    krismusic and Ripley like this.
  8. Ripley
    Thank you! It's too bad Creative can't team up with Sonarworks (or Inner Fidelity), which has already measured tons of headphones. That would greatly expand their list. Here's hoping they periodically keep adding more headphones to their "supported" list. I'd love to see some Audeze and MrSpeakers models get added to that list.
  9. obiwon
    i have used the audeze isine20 with sxfi and can say it works. but i dont have the app so its just the general profile. since this is an iem it is less out-of-the-head than an over the ear but still 10x better than plain stereo. i will be testing the LCD series in a few weeks and will report back.
    Ripley likes this.
  10. obiwon
    i suppose you could pair the sxfi with the waves nx headtracker or else pair it with an audeze mobius.
  11. phoenixdogfan
    Would be nice if they got a couple of LCD phones certified.
  12. ezekiel77
    Hi guys this is my review of the SXFI Amp. TLDR it does some things spectacularly but is not ideal for vocal-centric music.
    https://www.headphonesty.com/2018/11/review-creative-super-sxfi-amp/
    I might add this review to Head-Fi soon, but the item is not created yet and will take some time. It's a matter of copying and pasting from the Creative official website but the marketing department basically went wild with SXFI with all the hype. Eeehhh.
    Ripley likes this.
  13. SomeTechNoob
    I am in the lucky position to have obtained the SXFI amp and the bundled Aurvana Live SE. Sadly I'll have to wait until the US release of the app before giving it a full go.
    Quick thoughts:
    - Pretty nice aluminum build with clicky buttons.
    - Powered HD 6XXs in stereo mode to well above listening volume levels.
    - Holographic audio mode definitely seems to work the best on the Aurvana Live SE to my ears when compared to my other cans.
    I'll need a bit more time to really form an opinion, but it's a neat little portable dongle dac/amp. Works on both my Android phone and Windows computer. If anyone has any questions, ask away.
  14. InfernoFZ
    Head up the app can be use to update the amp firmware as well.
  15. edwardsean
    I asked Creative when the app would be released in the U.S., and they said that it should be available around the same time U.S. orders for the amp are fulfilled.
    Does anyone know anything more specific?
