Eurobeat
- Aug 15, 2015
Hello all,
I have this card from my old build back from 2006-2007. I really liked the card, and it came with a I/O box with a bunch of nobs to change settings from the software.
A lot of people seem to say that I should look into an external Amp/DAC but I do not see many choices for 5.1 setups (I have a 5.1 Logitech Z5300e speaker setup). The only one I see is the "Creative X7" which is a 400$ external unit. I am also looking for a new pair of Headphones, but I was looking at external Amps and DACs for that....
I bought a PCIe to PCI adapter, and wanted to use it in a new build since PCI slots are outdated and most, if not all new MBs don't have a slot for them....
I also found an external adapter that I could use for my laptop called the "EXP GDC Beast"which is a Mini PCIe to PCIe adapter, and then I could use the converter on top of that for the Sound Card...
I think the external way would be preferred, because I saw a video that was mentioning about the inside of computers creating tons of static and electric current flowing throughout the box, while the Sound Card itself is trying to eliminate all that stuff, so essentially there is conflict inside the box... I figure if the soundcard is now EXTERNAL it should perform much better... Right?
So I'm curious what people think of this card?
TBH I just realized now there are 2 listings for this device
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102191
as well as
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102015
Not too sure what the full differences are, nor which one I have tbh.... Idk where I would find that info either.....
So overall I really would like to use the sound card with my speakers, since I don't want the 400$ X7, but at the same time the converter was 35$(returning it tomorrow and shipping back was 8$), and the EXP Beast is 45-65$ depending when I get it...
It sucks It's been tucked away for awhile and hopefully still works, so I'm not sure about it all... I want to use my speakers with something better than my current laptop setup, especially since the front plug is wobbling and doesn't connect well. The speakers themselves are also dying as the RCA inputs on the back are wobbling, however I could buy another Woofer/motherboard for the woofer, plus I have a second woofer, so in a sense the best bet would be another mb...
So I really like these speakers, but not sure what I should do.. Especially since I am looking to build a new computer (but would it be able to handle the 3 inputs from my Logitech speakers)?
So I'm curious what people think...? Thanks...
as well as
