demol3
- Dec 2, 2016
I've just received an E5 after spotting it on offer so am new to this USB DAC thing. (I've been using a headphone amp for a while now).
I actually have three Android devices I want to use it with, which all sound different using the headphone amp. I was hoping the E5 would mean I could achieve a uniform sound whichever device I used (assuming the settings are the same), as only the E5 is doing the DAC work.
So let's take the Samsung Note 4 (my main device) as the focus. I have installed the Soundblaster services and the Central app, and everything 'works' but while listening it is as if the E5, or Note 4 is changing driver or mode every 10s and the sound stutters very briefly, but then sounds different. I've been playing with settings in Neutron and Poweramp and it happens with both.
The E5 is hooked up to the Note 4 using the Host port on the E5 to the Micro USB port on the Note 4.
It can't be listened to with this constant stuttering and I'd be better off going back to just using my Fiio E12 unless I can sort this out.
Help.
Have you tried to turn off all EQ feature? Tried with different player? or over bluetooth?
