Crackling sound
Feb 13, 2017 at 4:31 PM Thread Starter Post #1 of 6
ls13coco
BC, Canada
So, I had this issue about a month back where primarily while browsing the internet my audio would crackle.
I did some searching, ended up finding a bios tweak that fixed the problem.
Now, it's started up again and seems to happen while browsing the internet, or minimally while playing a game.
Using the Creative X7 sound blaster with all 4 upgraded op-amps (problem was first fixed with bios tweak before op-amp change, changed them about 2 weeks ago) and Fidelio X2, Akg K712, HifiMan HE400i, Klipsch Rp160M speakers and jvc thg300 receiver.
PC: win 10, i5-4690k 4.2ghz, MSI gtx 970, 16gb ram.
With music I'll use foobar with wasapi event yet the problem is present in spotify, streaming movies/shows and playing games.
Thanks for any feedback.
Feb 14, 2017 at 11:22 AM Post #2 of 6
I've been getting the same issue myself with either SPDIF or Violectric USB out at 2ch 24bit 96khz on pandora. Its most noticeable using the online tone generator @ http://onlinetonegenerator.com/
Feb 14, 2017 at 2:59 PM Post #3 of 6
I'll check that out when I get home.
I ran some latency tests and it seems kernel is the main culprit.. not sure what I can do about that!! Also cpu 0 has some latency cause
Feb 14, 2017 at 10:05 PM Post #4 of 6
Feb 14, 2017 at 10:55 PM Post #5 of 6
That program is inaccurate IMO. I play Spotify while downloading videos and browsing frantically all at the same time and yet I get ZERO crackling. Also, latencymon shows my system has trouble with audio playback yet, my lowly 1.9 GHz i5 dual core CPU only exerts 10% CPU usage.
