Beefy
- Mar 4, 2008
It required drilling of the panel to accommodate the locking pin.
This is a great amp period. Crack and HD800 are making some sweet sweet music right now...thanks and kudos to the folks at Bottlehead.
Crack amp is using 6080 tube, and as the 6AS7G are both tubes that are very musical, dynamic, and cheap! My La Figaro 339 is using 6AS7G in dual mono configuration and it has even more authority, clarity and good sound than Crack! You should also check out other 6AS7G/6080 tube amp out there, they are gorgeous and tube rolling is affordable and fun!
It is pure hypothesys, double power supply vs single in all the other gear I tested including mostly power amps and loudspeakers. Soz didn't want to bash you new acquisition! It seems Crack is great buy for the price!
I got my Crack/Speedball recently expecting some cheap fun with good amount of coloration, but I'm seriously surprised by how good this amp sounds. Much more neutral than I had anticipated, with excellent control and detail. This is a great amp period. Crack and HD800 are making some sweet sweet music right now...thanks and kudos to the folks at Bottlehead.
Can you compare your Crack with GS-1 as to how they play with HD800?
They are both very good with HD800...
