The new D-series has bluetooth and volume wheel.
http://m.cowonglobal.com/product/PLENUED3/
Yeah i know that, am just asking about other DAP offering same or similar sound outputNo other player has BBE only Cowons. You may want the newer D3 like stated above.
or the R2 for a device similar in size to the PDI would recommend HiBy DAPs. Their MSEB is a piece of nice software. I own R3 Pro and love it. For a proce you could get R5 or even R6.
Thanks for all the suggestions here! @bachankas @Barndoor thx for the Hiby recommendation + pics!! You got me really considering hiby DAPs.or the R2 for a device similar in size to the PD
Thats funny, they had my Plenue D since September 4th last year... i always inquired with Jet Audio, and always got a Generic Response... "I'm a long time lurker on this thread and thanks too all with you knowledge, it has helped me a ton!
special thanks to @Brucebenner for his tweaked BBE settings, they're just amazing!
Question: My PD broke down after 1.5 years of use ( got credited back $179.99 from amex + 4179.88 from amazon so essentially i was paid $179.99 for a year of usage, not bad mind you ; ) ) and i'm looking for a new DAP which wont disappoint me after being used to the Jet effect /BBE settings.
Which DAP-any company- would you guys recommend in the sub $400 area which will be as good as using Bruces' settings on the PD
Thanks
Yep. Mine bricked. I tried all the button combinations and letting the battery run down. The screen is frozen. The only that does anything is the volume number responds to the volune buttons but thats it. The place thatis meant to service them doesn't even respond to emails.Has anyone had their plenue D just die... mine wont take a charge, wont respond to the -/+ reset... just dead. Had it since they came out. I put it on the USB charger, nothing, on the laptop - nothing.
