Cowon Plenue D
Discussion in 'Portable Source Gear' started by aerosatan, Nov 30, 2015.
285 286 287 288 289 290 291 292 293 294
296 297 298 299 300 301 302 303 304 305
  1. DancingShaman
    Any of you my fellow PD owners having a freezing or “invalid file” issues while trying to ply certain albums / songs. I made sure that I uploaded less than 120gb of flacs only musk on a 200gb sd card. Can’t quite edifice it what’s wrong? It sure is annoying as hell though.
    Any ideas??
    Cheers.
  2. HiFlight
    Have you made certain that you have not exceeded the file and/or folder limits and your card is formatted as FAT32? Also player should be turned off before inserting or removing your card.
  3. DancingShaman
    Absolutely my friend. Formatted in fat32 and since all the files are high res flac files, it is definitely less than the file limit of the player. Quite annoying..
  4. HiFlight
    Also, note that Flac playback is limited to 24/192 max resolution. If your files do not exceed this, perhaps it is a card issue.
  5. technobear
    It could be a fake card or it could be that the files haven't ended up in the lower 128GB of the card or you might just have some files that are incompatible or corrupted.
  6. ElKabong
    There is the possibility the the suspect files are improperly tagged. Just putting this out there.
  7. DancingShaman
    Thanks, will double check that. I sure hope that is the case.
    How to make sure that all the files are stored in the lower end of the card? Never heard of this issue before.. Many thanks!
  8. Eggs is eggs
    My Plenue D came today. This is actually my 3rd Cowon mp3 player. A while back I got an iaudio 9, then a few years later upgraded to the iaudio 10 and then got the plenue D.
    First impressions are that the sound quality is the typical great cowon sound quality. It's also smaller than I thought and I like how it has both touch screen controls and physical button controls. I organize all my music via folders on my computer and a quick copy/paste onto the player and everything works fine, including album art. The iaudio 10 had problems with album covers not loading but only a few here are showing up without the covers loading.
    The UI is also typical cowon: Nothing special but it gets the job done. No complaints. However, the UI lag is definitely there and is annoying. Not a dealbreaker but how did this get through QA? I guess they didn't care or didn't want to spend more money on a slightly better processor?
    One annoying thing is that the physical skip track buttons are reversed, I feel. If you hit the one facing up, it goes backwards one track and the down facing one goes forwards a track. I'm sure I'll get used to it but I'd like to reverse them if possible.
    I haven't had a chance to test the battery so if it gives anywhere near the advertised 100 hrs for mp3s and 50 for flac, I will be more than happy.
    Overall, I'm impressed with it. I'd rate it a 4 out of 5.
  9. technobear
    You guys complaining about UI lag have updated to the latest firmware haven't you? I believe it was an issue on earlier firmware.
  10. El Gringo
    +1 technobear, I have FW 1.17 and no complain about lag :thumbsup:
  11. Mython Contributor
  12. technobear
  13. Nebucatnetzer
    I reckon this highly depends on your expectations.
    However it's a fact that the Plenue D is nowhere near a modern smartphone with a 60FPS refresh rate.
  14. Eggs is eggs
    I think they just cheaped out on the display. Maybe lag is the wrong word to use. It's just not as responsive or fluid as I expect it to be. Which I can totally understand for a budget player released in early 2016. If they have to cheap out on anything I'm glad it's that rather than the sound quality. The device came with the 1.17 firmware which I believe is the latest version. You get used to it and again it's not a dealbreaker.
    mdtolic likes this.
  15. Mython Contributor
    I'm less forgiving of Cowon's shortcomings with their budget players, but there's a very good reason for that.
    I am a huge fan of the J3, and in 7 years, Cowon have succeeded in going ...backwards.
    That's unacceptable for one of the market-leading companies in the DAP marketplace, during more than the past decade.
