Cowon Plenue D
Discussion in 'Portable Source Gear' started by aerosatan, Nov 30, 2015.
250 251 252 253 254 255 256 257 258 259
261 262 263 264 265 266 267 268 269 270
  1. doppelgangerLT
    Guys, I'm very sorry for the newbie mistake - I wanted to reply to a post where a user asked if the PD will sound better than a good smartphone and which one of the phones he should get. Then I saw that I replied to the global thread and tried to delete my post but posted it again somehow :frowning2: Is there a way to delete the double post?
    And thanks everybody for all the information, you were an inspiration to order a gold/black version of PD from the UK, will get it in a week.
    Best regards from cold (-9C at the moment) Lithuania!
  2. doppelgangerLT
    And how does the Plenue D sound compared to Oneplus 3?
  3. Rockin_Zombie
    Plenue D is very different from the other players. Most audiophile devices boast what DAC chip they have, for Plenue D you actually have to dig deep to find out (some modest wolfson chip don't exactly remember which one). So a lot of phones will have better audio then Plenue D, theoretically.
    But the battery life with BBE is what sets it apart. If you really care about critical listening or listening to the "true recording" Plenue D is not the player.
  4. Vitor Valeri
    Here is the Cowon Plenue D open and all player specs: http://www.head-fi.org/t/789488/cowon-plenue-d/2865#post_12631507
    Rockin_Zombie likes this.
  5. Nebucatnetzer
    In my opinion the PD has more detail. However it depends a bit on the music
    and the player you're using on the Oneplus. Depending on the music and
    with a good player like Poweramp it can get hard to notice a difference.
    One thing which is quite noticeable however is that the PD has a much better bass.
    I'm not really good at describing this things but on the Oneplus
    the bass is a bit weak in general and if you push it with an equalizer it doesn't
    sound very good. The PD starts with a bit more bass and if you push it with
    the equalizer or the JetEffects it still sounds good.
    I'm using it with a Sennheiser HD 25-1 II and Etymötic hf5.
    doppelgangerLT likes this.
  6. doppelgangerLT
    Thank you, now I'm very eager to compare Plenue D with my Galaxy S7 - it also has a rather weak (or rather "muddy") base, especially if I try to hook my Grado SR225e. Sounds more or less OK with in-ears though.
  7. slowpickr
    I've renamed my PD to my "wonder box".
    FraterOiram likes this.
  8. Vitor Valeri
    Comparison: Cowon Plenue D Vs Sony NW-A35
    http://www.head-fi.org/t/832786/comparison-cowon-plenue-d-vs-sony-nw-a35
  9. FraterOiram
    Any one?
  10. Tokyoghoul
    Change the file name to user.ttf and put it in the systems file.
    Nebucatnetzer likes this.
  11. GoldenTooth
    Hello, i own a dragonfly black Sabre DAC 9010) for my PC  (nice audio but sounds too bright and fatiguing also lacks little bass) , also a Samsung note 5 (Wolfson DAC) (more relaxing audio than dragonfly but so lacking in depth compared to my dragonfly)
    Since portable DAC and a phone give me so much hassle [​IMG]
    I decided to buy a dedicated DAP but i am having a hard time deciding between Cowon plenue D  and ibasso Dx50  .  did any one compared them A/B  comparison regarding audio quality? . [​IMG]
    All i care about is audio quality only (no battery , ui, design.....etc)
    Please need help deciding since i didn't find any regarding to them in forums.
  12. Martin Zeef
    Can someone help me? I bought a Plenue D on eBay but it has a problem: It starts up and asks for selecting the language, but I can not select one. There seems to be a touchscreen problem or the UI 'freezes'. Does anybody know how to solve this problem?
  13. Vitor Valeri
    Format and reinstall the firmware.
  14. Martin Zeef
    How does that work? Just delete everything and put FW1.17 on the player?
  15. Martin Zeef
    Can I format the internal memory and put FW 1.17 on it?
