Cowon Plenue D
Discussion in 'Portable Source Gear' started by aerosatan, Nov 30, 2015.
229 230 231 232 233 234 235 236 237 238
240 241 242 243 244 245 246 247 248 249
  1. Divine Fang
     hi all, i have been listening to my ipod nano 3rd gen and iphone 4 (some 320kbps mp3 quality and some Apple Lossless) using B&W P3 headphones and i am looking for an upgrade, will i hear a significant difference if i buy the Plenue D? thanks!
  2. Carlosfandango
    Awesome, little device arrived today.
    Charged and loaded with music.
    Vitor Valeri and jmills8 like this.
  3. jellyjam
    I was gonna ask almost the same question.
    I have the S9, works fine, battery life still good enough, no problem with the sq.
    So what's the difference pleneu d might offer. Interesting to hear that much difference in the sq?
    Is there that noticeable difference on the positive side at plenue d?
  4. Vitor Valeri
    Yes, the difference in sound quality was clear in Plenue D, much better.
    Yes, it is a considerable difference.
  5. GilZ
    Should be OK !
    It drives my AudioTechnica CKR10 (12ohms) easily
    Yours are 36 ohms, should be easy to drive too.
    But PD can t drive my Sennheiser HD650 (300ohms), not enough power.
  6. Carlosfandango
    While I'll happily spent hundreds (and in some cases thousands) on Headphones, DAPs, Turntables etc.... I simply CANNOT find it in myself to pay nearly £40 quid for a cover/case.
    http://www.ebay.co.uk/itm/Inateck-Felt-Storage-Pouch-Bag-Case-for-Accessory-Mouse-Cellphone-Cables-SSD/272385575727?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D37123%26meid%3De7af00ee868944f9aa756cb6c4d3e945%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D351736778277
    Hence, my solution to the problem. Small felt case that the PD and a set of 'phones can travel around in.
    Simples.
  7. jmills8
    No case, put in pocket.
  8. Carlosfandango
    Yeah, I've read several times that you don't keep a case. Brave man :xf_eek:
    Any you not concerned for scratches and bumps? Or does it simply not pick any up?
    I always have Keys/Money in my pockets... so worry that it'll mark.
  9. jmills8
    keys in other pocket.
  10. apaar123
    Is it worth buying?
  11. Rockin_Zombie
    Bought a DAP after a long time, last time I owned a DAP was 2008 Cowon D2. They have improved the interface A LOT, people who used Cowon players in 2008 should know lol.
    Absolutely loving the BBE effects. Can't beat that while commuting. I have always wondered why BBE effects are so much better than what I can do with band equalizers, perhaps it's parametric? Anyway, very happy to be jumping back on the Cowon bandwagon.
  12. apaar123
    how does it compare to ak jr any idea?
  13. Rockin_Zombie
    No idea. As I said, went back to dap after 6
    years. Plenue D was the choice cuz of previous love affair with BBE and battery life.
  14. apaar123
    i am buying a dap for the first time so will this be good and which dac does it consists of?
  15. Rockin_Zombie
    Nothing fancy, Wolfson WM8998
    http://www.toutiao.com/i6242024182998106625/
    If you are looking for a "boutique DAP" this is not it. Plenue M2/S is what you will be looking at. But you lose out on battery life if you get those, also much more expensive.
