You can try to contact them and ask if they'd be willing to sell you one. If you don't mind it being a different look/design, you can find right-angle adapters easily on eBay/Aliexpress.
Contact them about it. Only other ones I have and found are on amazon, plastic ouside, but gold plated.
In this case it was USB (on PC/Desktop with Windows 7). But the other albums I used the card reader of my notebook/laptop (Windows 10). Note: When formatted the micro SD card, I used the card reader of my notebook. Formatted with the Windows tool and then used the formatgui program to format again.
I runned win tests on SD. Errors were found. Sadly still gapping on gapless album 24bit/192khz flacs. Need time and patience to reformat the SD.. Meanwhile I'll use internal memory for gapless max bitrates flacs. Damn, God knows I'm tired about it.
I never have a problem with my D. Just copy all my flac 16bit and 24bit to internal memory. All are very good.
MMM, I have an issue with my PD. I believe with a push of a button it can be resolved. When I put my PD away and I dont use it say for a week its battery dies. Is it not really turning OFF when I put it away for a long period?
In Windows format tool (click on the right mouse button on the unit and selecting the format option): FAT32 with 32KB allocation unit size. In Guiformat: the program automatically recognizes the allocation unit.
Problem is win vista has only NTFS and exFAT. so I'm full formatting NTFS 32K on vista and will full reformat FAT32 32K on guiformat. +- 4 hours to do this all. Fingers crossed.
By the way - when you're formatting, use the 4096 size allocation. That's what your average hard drive does and it's the best balance of speed and power usage.
