Cowon Plenue D
Discussion in 'Portable Source Gear' started by aerosatan, Nov 30, 2015.
209 210 211 212 213 214 215 216 217 218
220 221 222 223 224 225 226 227 228 229
  1. jmills8
    I hate W10.
  2. leo5111
    W10 blows dogs
  3. slider22
    Ill try to copy some files later on a different W10 laptop. Ill keep you guys posted
  4. Scalpos
    It's not W10 related. I encountered the same issue using W7 (with and without Teracopy): sometimes when a lot of files are transferred, directories and their content were properly copied, but some of the directories are shown as empty by the DAP. There's seem to be no logic, and the same files can be played when the DAP is mounted on the computer... A database refresh did not help... I had to delete those directories and copy them again.
  5. seanjoe
    Waiting new fw. Really hope D will makes friend with Mojo..
  6. slider22
    I tried copying 1 album only. PD didnt detect the files. There might be some compatibility issue with the pd and w10
  7. rockwell
    do you mind telling me where to get this angled adapter? thank you :)
    doppelgangerLT likes this.
  8. technobear
    I use MediaMonkey to load up my DAPs. It's nice because you can customise the directory structure/file naming and convert formats on the fly regardless of how the files are structured on your PC.
  9. slider22
    Thank you, ill try this when i get home. Ill let you know how it goes :)
  10. fl4viomc
    Still getting clicks from changing tracks of Dire Straits Alchemy Live album on SD card. FLAC, 24/192.
    Meanwhile, Pink Floyd's Pulse gets gapless on internal memory. FLAC, 16/96...
    Anyone with very similar issue? FW 1.14.
    Just noticed that now. Haven't tried any other FLAC bitrates on SD either internal.
    Thanks!
  11. Vitor Valeri
    After I updated the firmware 1.13 to 1.14 this problem disappeared. After you said that I tested the album Diana Krall Quiet Nights (FLAC 24bit / 96KHz) on micro SD card and did not detect any click.
  12. fl4viomc
    Is the album on your SD or internal memory? Thanks!
  13. Vitor Valeri
    On my micro SD.
  14. fl4viomc
    hmm.. seems like FLAC 24 bit/192 khz is not good for D indeed.
  15. Vitor Valeri
    I'll test tracks in this configuration and I will tell you later what happened.
