- Jan 10, 2016
i pair pd with topping nx1 (volume 85) and it turns out fine
Wow. The D must be creating the files again. There are system files on it. Maybe they are ROM based or something, pretty weird. I'm not willing to do it. LOL
More likely the system files are on a hidden partition so they can't be deleted if you format the internal storage
I honestly don't understand the volume complaints. I am using the D with my 250 ohm Beyerdynamics and if I turned the D on fully it would blast my ears away.
a truckdriving ?
Does somebody experience this behavior: The Plenue D does not go to sleep when unplugging the headphones while it plays a song with the screen dark? For me in some instances the on off switch keeps flashing and it does not go into sleep mode. If I press the on off button I can see that the track indeed stopped when I unplugged the headphones. So going to sleep was not prevented by still playing music. On other occasions the Plenue D properly goes to sleep. I don't know how to reproduce this behavior. Any suggestions are greatly appreciated.
Watch these videos, may help (even with the language in Portuguese):
Thank you for your fast reply. Unfortunately this explains nothing to me. As I said: Sometimes the D goes to sleep properly when I unplug the headphones (while playing a song and the screen is off) and by this I mean after the countdown of the auto off minutes (standard setting like in the video), and some times it does not go to sleep after the set countdown time. It keeps flashing![]()
It is because it has two types of regulation on the player to turn off.
You have the time to turn off the display automatically (without pressing the lock button) you can regulate.
It has the automatic shutdown time of the player if he stays with the paused music.
It has the sleep mode feature that causes the player to enter hibernation mode (as in the notebook when you close but not turn off the power). If this functionality is not enabled, the message indicating that this shutting down.
It is also possible to change the settings for the LED stops blinking when the screen is off (during playback).
