cowon j3 on PC - problems?
Sep 1, 2010 at 2:10 PM Thread Starter Post #1 of 3
j57park
Hi, I was wondering if the j3 is as buggy on PC as it is on MAC OS X.
I normally use my macbook but if I do get the j3, I'll be using my old PC desktop (WIN XP) to do all the j3 related stuff. I'll be transferring the music files over a USB drive from my macbook to pc then to the j3.
I had D2+ for mac that was really pain to use so I was wondering if there are any PC cowon j3 user who has complaints about bricking or flashing white screen. Are those problem only for mac users or are they still possible with pc users
Thanks for your help!
Sep 1, 2010 at 7:33 PM Post #2 of 3
tds101
Formerly known as nywytboy68
The Cowon DPA's have no probs w/a PC running Vista. My J3 runs fine, just keep playlists off of the microSD card - THAT causes the player to go buggy. Seems Cowon really hates playlists,....................
Sep 1, 2010 at 9:13 PM Post #3 of 3
j57park
Thanks for your response!
One more,
if I install parallel on my macbook and run windows xp on my macbook, that shouldn't pose any threats since I'm virtually running window operating system right?
