Corda Kit Ground Problem
Jan 11, 2003 at 4:58 AM Thread Starter Post #1 of 1
Whit
I thought I had fixed this but apparently not. When I touch my Corda's volume knob when it is at a volume below 8 I get a hum. I thought I had fixed this by wrapping some wire around the alps screw and soldering the wire to the alps ground pin but I still get this hum. It is less apparent in the 120ohm jack but still there. It is undetectable while using my DT931 in either jack. What could be causing the trouble? A bad solder joint? This is starting to drive me crazy.
Thanks.
Whit
