conecting transformer for dynahi power supply?
post-1416014
Thread Starter
Post #1 of 6
SilverCans
I have a question regarding how to wire the transformer. I'm not sure if I should wire the primaries in series or in parallel (in either case which wires go to the neutral and which to hot)? What's even more confusing is the picture on the label of the device, it doesn't exactly match any of their examples (the they have hot going to different color wires then in their illustration). Below is a pic from Avel's website.
post-1416032
Post #2 of 6
Jazper
I don't know what voltage you need, but:
for double the current run both windings in parallel eg:
black-orange
Red-yellow
and connect the pairs up to wherever you need
for double the voltage (70v AC! considering you're running 35v out of the transformer):
connect:
orange-red and use black and yellow to connect to whatever you need
if you want 2x35v just use black, red and yellow, orange to connect to a device
The windings on the input side are the same - for 110-115v input wires in parallel
for 220-230v input wires in series
In AC you don't have Hot and Not :p, you just have 2x hot.
post-1416090
Post #4 of 6
amb
Member of the Trade: AMB Laboratories
What country do you live in (i.e., what AC mains voltage do you have)? This info is essential in order to wire the transformer appropriately.
post-1416157
Post #6 of 6
amb
I live in the USA (~115vac)
OK, then you'll want to connect the primaries in parallel (blu/vio, gry/brn).
The secondaries should be independent if you're using the dynahi PSU, each secondary feeding its own set of bridge rectifier diodes.
