Concise Multi-IEM Comparison (FINAL UPDATE March. 1st, 2013)
post-8572934
Post #751 of 1,240
ClieOS
IEM Reviewer Extraordinaire
Middle of Johor, Malaysia
Website
InEarMatters.net
I read them perfectly fine, and I double check the result using another IEM. As I said, my M4 sounds normal, as with the IEM I used for double checking.
You forget that, with IEM, everything will play 'inside' your head. That test is designed for speaker, not IEM.
post-8575506
Post #752 of 1,240
szjwt63v
but. same polarity matter in speaker and iem and headphone.
post-8575615
Post #753 of 1,240
ClieOS
Website
InEarMatters.net
Yes, but the way of interpretation is different. There is no such thing as out-of-head anymore when you are using IEM. Just a varying degree of in-the-head.
post-8576199
Post #754 of 1,240
dfrost
I have Fischer DBA-02's modified with Westone sockets (see my avatar), which allows me to very easily switch polarity on these BA IEMs. I visited that polarity-check website and tried all the tests, using one of the connectors in both configurations. At best I heard only tiny differences, and those were not consistent as too which was "correct polarity".
Maybe it's just the nature of BA IEMs, but it leaves me with the answer that polarity doesn't matter.
post-8577115
Post #756 of 1,240
ClieOS
Website
InEarMatters.net
post-8577509
Post #757 of 1,240
szjwt63v
thank you for your report. :)
post-8578122
Post #759 of 1,240
ClieOS
Website
InEarMatters.net
Any ETA for your EPH-100 review? :D
Not any time soon, unfortunately. Still have a long list to go through before it hits EPH-100.
post-8578216
Post #760 of 1,240
putente
Oh well, I'll just have to keep wait then...
post-8579003
Post #761 of 1,240
Moosecraft
how do you feel about the ck100 pro compared to others in its price range?
post-8580056
Post #762 of 1,240
ClieOS
Website
InEarMatters.net
I think it is hard to talk about VFM (value-for-money) factor for any IEM pass over a certain price point of (say $350~$400). But if there is only one universal IEM I can have, it will probably be CK100 Pro.
post-8580421
Post #763 of 1,240
Inks
An expert on his own opinion.
That's maybe because the polarity of your DBA02s were already fixated when Brian placed those Westone sockets I believe. Unless he corrected the polarity when he faced them, either way it's not an issue as long as both are done the same way, inverted or absolute.
Both the B2 and DBA02MKII have inverted polarity, very likely the DBA02 mkI is the same. Which again isn't an issue at all when both channels are matched this way, so nothing to worry about.
post-8599677
Post #764 of 1,240
Zelda
if i'm not wrong, the re-zero and re-262 review was made in the non-balanced plug mode. did you have a chance to try them 'balanced' as the re-272 ?
post-8599858
Post #765 of 1,240
ClieOS
Website
InEarMatters.net
Yes, unless mentioned, all review are done with single-ended setup. My RE262 is an early prototype without the balanced plug, so I can't listen to it on balanced amp. However, I do have a StepDance, which is pretty close to being an balanced amp (as compared to the balanced amp module on HM801) and I can say that neither Re-zero or RE-262 benefit as much on balanced amping as RE-272.
