xII DM IIx
- Mar 17, 2011
What are some other high end IEMs with a 'balanced' sound sig like the TF10s? Anything that would be a noticeable/refined improvement?
really? but didnt you rated the Eterna higher on 'the list'?
Hey ClieOS,
How would you compare the GR07 to the RE0 in terms of clarity? I see that you've classified RE0 as analytical (as it should be) whilst the GR07 is warm sweet, how "much" warmer is the GR07? And also, how is the isolation with the GR07?
Actually RE0 is a bit warm too. I would say GR07 is about the same level of warmness as RE0, but with much better bass extension while RE0 has much better treble extension.
If you use decent foam tips (i.e. JAYS foam), about average (-20dB or so). If you use stock silicone eartips, slightly below average.
Have you used the PFE with foam tips?
Interesting as PFE with Comply foam is much more isolating than RE0 with big bi-flanges for me. Though I have no idea which tri-flanges you are referring to.as I have never seen a shallow tri-flanges before.
ClieOS,
About the Shure SE215, do you believe the process of break-in can improve graininess that there is on the upper vocal?
ClieOS!
How do/can you stop yourself from impulse buys? Or is your thread the result of it? Haha. I currently see some Vsonic R04 Pros for £38 delivered which is really tempting, I know the GR07 will be tons better but I'm not really into spending £100 for something that I know won't isolate well but say for example the Vsonics R04 Pros isolate well, then I could perhaps sell them and go for the GR07? Ah I don't even know what I am talking about, with that theory I should just get the GR07s right?
ClieOS,
ClieOS!
Oh, you should get the GR06 instead if you can. I really like its presentation over GR04.
they're for $50
what they sound like?
