Comply tips - how long to they last?
Nov 15, 2008 at 8:47 PM Post #16 of 27
hockeyb213
BANNED: BAD TRADER
have fun
Nov 16, 2008 at 1:50 AM Post #17 of 27
athenaesword
Originally Posted by huimun /img/forum/go_quote.gif
good pair of tips are just like great running shoes! there isnt any good runner who can run bare footed or with a pair of lousy sneakers(unless they're like haile gebrselassie who's been running barefooted since young)
or Abebe Bikila. bastard won the Rome Olympics marathon running barefoot.
Nov 17, 2008 at 11:33 PM Post #21 of 27
tnmike1
I've used both the Olives and the Complys. Notice a slight bit of bass increase with the Olives, which to me was quite pleasurable. BUT--I'm listening to jazz and big symphonies so the bass isn't that pronounced. DOn't know how the increase would work for trance, hip-hop or similar genres
Nov 17, 2008 at 11:40 PM Post #22 of 27
synaesthetic
Shure olives are a good match to Etymotic earphones, which are generally considered to be bass-deficient and overly bright. The olives both gently tame the highs and give it a bit more low end.
Nov 18, 2008 at 3:17 AM Post #23 of 27
qusp
Member of the Trade: Twisted Cables
Of course tips make a difference; are you crazy??. I also find the olives to muddy/bloat the bass on my SE530 so I use comply; I get 3-4 weeks out of each pair. but mate, rather than buying a huge bulk amount I would get the westone UM57 or sensephonics custom molded tips now they would really make a difference. There is better isolation on the olives by a smidgen, but its really negligible
Nov 18, 2008 at 3:52 AM Post #24 of 27
hockeyb213
BANNED: BAD TRADER
I was thinking about the customs molds and I determined it really matters on how my livewires turns out. If they are so good that I only will use the tf10's as a backup pair which will only be picked up once in a while then it will be a no. But if they turn out fairly = to each other I may invest to get some custom's to make em more comfortable. But I am scared at how far they really stick out
Nov 18, 2008 at 11:04 PM Post #25 of 27
LordEntropy
My Olives last me months as I clean them gently periodically. So are the complys likes the Olives in that they are a more sealed foam than say the original foams that Shure used to supply? The ones that seemed to absorb and discolour with wax ?
Nov 19, 2008 at 1:40 AM Post #26 of 27
urabus
How do you insert Complys? I read they are heat activated so do you just stick them in your ears or do you still roll them smaller like i do with the olives before inserting? Thanks.
