Micro Meet
Well Vlad (vvs_75) came over today with his edition 9s and did a couple hours of listening. He couldn't hear any difference between my two amps either. His own 4 board beta22 (with 4 sigma22s) unfortunately suffered a failure mere hours before we were supposed to meet (he had just cased it and there was a problem) so we haven't done a comparison to his premium component beta22 but his impression (Vlad correct me if I'm wrong) was that the only difference he could be sure off is that his high quality stepped attenuators didn't crackle when changing the volume and mine did
(they don't once properly engaged don't worry).
Edition 9's
The edition 9s were nice but not my cup of tea. Very good rock phone but a bit uneven and over bassed for me.
Comparison Conclusion
For my ears and my headphones the two amps perform identically for me in the sonic sense.... Which means that both of them are jaw droppingly good at what they do and just plain amazing amplifiers for headphones. I am almost entirely convinced that if I did DBT on a these I'd not be able to tell the difference.
The GS-X
It's a headphone amp first with both SE and balanced drive and a preamp with both balanced and unbalanced outputs. It also has loop outs and balanced and unbalanced input. As far as connecting various things this is probably the most versatile amp I've ever seen
To boot for the headphones that I own it is as transparent as it comes.
The beta22
The beta22 I would say is much more versatile as far as load but for most headphones I feel that its performance is possibly going to waste, that said it can generally be built and or obtained for less than the GS-X which is a plus. I'm sure a beta22 with all the extra connectors and unbalanced to balanced transformer would drive a beta22 up to the GS-X range especially if it was cased to the same level.
My particular unit is balanced only which is another issue for me but not a big one. A little solder can fix anything right?
Prologue
I've reached my audio nirvana and not with one but two amps
life doesn't get much better than this. I'm going to miss wanting to upgrade though. Honestly I sort of miss it, on a psychological level it's more fun to want something than it is to have but then you just have to think about what you have in front of you. Also the e500s that I have to listen to at work always remind me what I have at home
