Colorfly C4 HI-Fi Player
Discussion in 'ALO Audio Premier Sponsor Forum' started by kb, Apr 6, 2011.
  1. kiteki
  2. ElCrazo
    Not too expensive at all. C4 is in fact good value if you think of it. Most folk have a rig - Player/Dac/Headamp, that's expensive and a pain. The C4 is as good as most rigs just on its'own and it has S/PDIF in and out.
  3. ElCrazo
    "Hopefully Colorfly will address this Flac limitation with a firmware upgrade in the near future" Very doubtful and not necessary. As far as I'm aware there are no players (portable) out there that can play hires FLAC files. The C4 has 'forced' me to look deeper into many things and ideas. Conclusion - the biggest single problem we all have is the poor qulity of original recordings and downloads in partricular. If you want to know how good a player really is then it's easy. Take your favourite CD - extract the files in WAV using EAC - these will be 16/44 - put the files on your player - and LISTEN. When I first got my C4 I got 'sucked' into wanting hi def - waste of time in most cases. A good recording in WAV 16/44 is, on the, C4 SUPERB and if you want then you can upsample anyway. Who do you think gains the most by using FLAC ?? Find this out and you might get a surprise.
  4. kiteki
    Wait.......... what exactly is it you're saying... that WAV sounds better than FLAC...?
    Hey ElCrazo, if you upsample to 24/192, then you have in practice extended the bandwidth from 20Hz-20kHz to 1Hz-96kHz.
    HOWEVER... you are not hearing any of that information above 20kHz, since ALL IEM's roll-off usually around 16kHz... the solution is for you to get the BATPURE!!
  5. ElCrazo
    Yes, I understand all that but...........1. Yes I think Wav does sound better but you need good files and a high resolution 'system' to notice. 2. Not quite true, when I feed my C4 into a valve pre/power amp / custom speaker set-up which goes to about 28Khz. Besides, I have said in other posts I don't often find a need to upsamle. All I said is that you can if you want. Psychoacoustics play a big part in all IEMs' Do you really think they can go down to even 20Hz ? That's one of the things about the C4 - it has S/PDIF out. Since it can perform as a transport far better than most 'off the shelf' CD players that to me is a bonus. I also don't often use IEMs despite having far too many of the things. I just collect and compare. Prefer full size headphones.
    Try this - download say a 24/96 FLAC file from HD Tracks and rip the same track from a CD in 16.44 WAV Compare the two, you might not hear a difference on your personal rig but I sure can and so do most of my audio nut friends.
  6. ElCrazo
    What is the cable mod you did to your Teslars? I don't understand    Almost all IEMs have three wire (common ground) the new Dennon 700s are one exception. So do most headphones and worse, some use the headband itself!! A simple mod is to use a 4 wire cable, Two wires to each driver improves most if not all of these. "is the C4 the best colorfly or something, and how much does it cost, and which one is fake, and not fake? and what internals does it have? i.e. which DAC etc".? Have a look at the Colorfly web site. You have T1 AND T5p T50s and 1350s  "what's the difference between C4 and CK4"? What's the difference between say a mini and a porche?
  7. ElCrazo
    Build:
    Cheaper and flimsier than the 50s—they were much easier to reassemble.
    Damping pad fitted to T1350s , to compensate for thinner housing.
    Wiring:
    The pictures speak for themselves.
    Different wire than the 50s, but still 3 instead of 4 conductors (Common Ground).
    One sided cable quite bad enough—look at how much extra wire is in the way of one side as opposed to the other.
    But worse there is a small circuit board glued inside the right housing, to terminate the three cables.
    So you have the left drive unit with an extra 55cm of cable (yes that’s 36.6% extra), and the right housing has a circuit board glued to it, which decreases the volume of the “Speaker”, and changes the resonant properties of the housing.
    In other words two different “experiences” for each ear
  8. kiteki
    I'm confused... are you saying the CD rip in 16/44.1 WAV sounds better than the 24/96 FLAC download?
    and yes, I think IEM's go down to 20Hz.
  9. ElCrazo
    "are you saying the CD rip in 16/44.1 WAV sounds better than the 24/96 FLAC download" Yes in a lot of cases, if not most. But certainly better than FLAC 16/44 downloads. Disc space is not an issue like it was a few years ago so files in WAV 16/44 are not a problem. It really comes down to the quality of the FLAC file on offer and not all are that good, I sometimes wonder if hires FLAC downloads have already just been upsampled. When I say RIP I really mean 'extracted' using EAC. If you look on forums about the QA QLS Player they will tell you the same thing.
    " I think IEM's go down to 20Hz " Think or Know? Read up on Missing Fundamentals and how this can be used in psychoacoustics. I'm not an expert on these things (who is) but after almost a full year of constant reading/studying/listening/ building speakers and comparing these are my conclusions and people I know who have systems costing as much as my house! I almost curse the C4 for starting me on all this [​IMG] BTW I've sent you that file.
  10. fixeman
    Hi Ken,
    When you say you can load FLAC 24/96 on the C4 does that mean you can play it? Supposedly you would only be able to play FLAC up to 16/44.
