i can help you
Colorfly C200
- Thread starter thepooh
i can help you with dac function
usb dac feature can be used in windows 10.
alexandros a
Do you often obtain screen frozen and stuck issues on C200??i can help you with dac function
I occasionally do and use a toothpick to reset the player...
SQ BTW.. is pretty good (I use Fiio E12A iem amp with C200 its a dynamic combo and you don't miss this way the first second from every track..
I use it as usb dac with laptop in windows 10 and it never stuck while using as dac.didnt listened for long as dap
If i get frozen screen i just press menu key for long and it switches off and then i turn it on again
ilmothedude
- Dec 20, 2014
Interesting that you got dac feature working with C200. May I ask what's the driver for win 10 that you use?I use it as usb dac with laptop in windows 10 and it never stuck while using as dac.didnt listened for long as dap
Yes will provide it.i got it from headfi someone posted 32 bit version for colorfly c10 so i converted his driver to 64 bit one and its working good.
https://www.head-fi.org/threads/colorfly-c10-colorfly-is-back.764823/page-22
i further modified his drivers to 64 bit and also removed that bleeping noise(every 30 sec) from drivers.
and used jriver + asio4all to get direct output.i get this little error and need help if this can be removed and this is not affecting sound or usb dac feature in any way but i dont understand what this error mean.
i am unable to run 192 khz file and jriver downsamples them to 96 khz than means i need better access to control panel of device or this seams like limitation of windows 10 for usb audio devices.
let me try same on windows 7 and keep you posted and tell me way to post the drivers.
best way so they reach every user of colorfly dap
should they be uploaded on mega and shared?
ilmothedude
- Dec 20, 2014
Use your preffered sharing method and share a link here, like mega or such. I believe you can also attach files directly here on your post, however I suppose there's some limit for file size.let me try same on windows 7 and keep you posted and tell me way to post the drivers.
sure i will point you toward the files
https://bt4g.org/magnet/d2c702f6f526831cb913a4a695cfbde34424b858
you need to first disable driver enforcement(watch that old 32 bit thread)
download this from that bt4g link here and this one will help you stop 30 sec bleep too
unzip that rar and replace the pguswdm ini file in above torrent.
atlast you need to install asio4all version 14 from their official site and you can use jriver with asio4all or foobar or direct windows sound through usb
procedure is similar to and if you get stuck or improve this then comment
I dont own any of this and major credit goes to the guy who created that 32 bit driver.
Hope colorfly can release native asio
This will work for all colorfly classic daps
update
able to get direct aiso 192 khz output and i guess it is bit perfect now and first i installed microsoft usb audio 2 drivers and updated another driver above them
