a review of low budget coffee gear
USB-rechargeable portable burr grinder.
Model "C-grind, 13w". Conical Burr. Detachable mid-hopper style. This type of USB portable grinder is being sold on Amazon for about $25, under several different "brands", they are probably all from the same factory.
The good:
-- grind consistency is good, similar to store bought ground coffee. Now I can get freshly-grind ground right before the brew, instead of weeks-old factory grounds.
-- wide enough fine/coarse adjustment to accommidate from espresso to drip (coffee maker) needs.
-- automatically stops when (it thinks) grinding is finished.
The bad:
-- there has been report of upper E-clip falling off (then jammed/damaged the burr) --> Needs modification.
-- the ground collection jar is not locked into place, it is held only by friction, can fall off if not careful.
The not-sure:
-- light-weight build, feels kind of flimsy.
-- plastic gears, not sure how durable it can be.
The hopper holds 26~27g of whole beams (Boyers espresso roast).
fine/coarse adjuster is at the end of the burr shaft. There are "steps", not very definitive but there.
(There is no marking on the adjuster. I made up the step #'s. #1= adjuster turned all the way in)
#1, about the same size/consistency of a store-bought espresso ground, say, Lavazza Rossa. Works well in my little Salton EX-96 (a basic, manual machine with non-pressurized portafilter).
Actually it is maybe a little too fine for the Salton, the pressure builds up quickly and the pressure-relief valve in the cap trips non-stop.
#2 espresso or moka pot.
#4 about the same size/consistency as pre-grounded coffee (eight o'clock etc), so I guess it is medium. We use it in a "Mr Coffee" coffee maker at work, with good results.
ground uniformity is pretty good up to this point. Not too much powdery fines, no boulders.
It can do coarser grinds but uniformity starts to suffer.
Ground doesn't stick to the collection jar. (slow grind, not much static build up).
Grind time:
(Boyers espresso roast whole beans)
#1 setting: 7~8 minutes to do 25g
#3 and #4 setting: 5~6 minutes to do 25g. There are usually some whole beans left in the hopper when it auto-stops, I have to shake the hopper a little then start again.
Noise level is not bad. To reduce the noise I just put it into the fridge and close the fridge door..... it will auto-stop anyway.
Or put a towel/blanket over it.
Charging and battery:
Charging is done via the USB-C port. The power switch ring flashes red when charging, turns solid blue when fully charged.
It will not grind while charging.
Battery voltage after two 25g grinds = 3.96v. According to info on the web this suggests there is ~70% capacity remaining, so each 25g grind uses ~15%
--> a full charge should be able to do 6 such grinds.
power consumption estimation: each grind uses 1250mAhx15%x4v=0.75wh, over 6 minutes --> ~7.5w
Internals:
to disassemble the top/motor assembly, first pry out the power button
then pry out the sub-frame/insert (probably not the proper name, but you get the idea). The plastic material is kind of soft, similar to what is used in a sports water-bottle, no risk of cracking here.
Marking on the silver Lipo pack shows 1250mAh.
gears are made of white plastic, don't know how durable but I suspect they will outlast the battery pack.
Mod:
there are two E-clips on the square drive shaft, the top one holds pressure during grinding (pressure from the coffee pieces jamming between inner and outer burr). There is a report in Amazon reviews showing this e-clip falling off during grind.
I replaced the e-clip with a lock ring after reading about this problem.
The locking ring was made using a flat washer with 4mm center hole. I cut a slot in the washer then widened the gap so it will slide over the drive shaft to the groove spot. Then clamp it into the groove.
The e-clip in the middle of drive shaft only holds light pressure from the adjuster tension spring, I left it alone.
This is a very light-duty grinder but the grind result has been very good. I bought it for work use, maybe 2~3 grinds a day. Lets see how long it will last in that role.
