cMoy power voltage problems
Feb 27, 2006 at 2:16 AM Thread Starter Post #1 of 11
aid3nn
Feb 27, 2006 at 2:42 AM Post #5 of 11
aid3nn
oh, alright, in all the guides, it states i should get about +/- 4.5 volts output because it splits the voltage. But if around 2.15 volts is correct for a single 9v then i guess ill keep building the amp. someone let me know if its supposed to be different. thanks
Feb 27, 2006 at 2:59 AM Post #6 of 11
Pars
Can Jam '10 Organizer
What does the battery itself measure? If its not about 4.3V then you do have something wrong. If that is the case, doublecheck all your jumpers and solder joints to make sure there isn't a short or a bridge.
Feb 27, 2006 at 3:11 AM Post #7 of 11
aid3nn
there are no shorts, the orientation of the pieces are correct, ive tested the batt. its 9.3v (new), ive tried replacing the caps, changed to 1% tolerance resistors. Ive posted pictures, i thought maybe someone here in the forums could see something i couldnt. if someone can spot the problem that would be great, because im going nuts trying to figure this out.
