Mr B
- Aug 24, 2012
I'm finding the sound a bit flat when i use the microphone thingy the Nokia comes with, but the sound is surprisingly good without it, even from a old cheap phone as the Nokia 5800 Music express. So if i'm going to enjoy the headphones with more then my laptop i might need a amp, but i'm sort of cheap, and the budget IS limited. Not quite sure where the limit is, but from the looks of things i should be able to snag a PA2V2 for less then 75 bucks. A CMOY is anywhere from a lot cheaper then that, to slightly more expensive, depending on what bells and whistles are included (and possibly, how much the seller fools you.)
Whats "the better deal" for my DJ100? Any particular sellers that are known good sources? PA2V2 is Ebay & grans-ar only, i think?
B!
Edit
Anyone things i'll get more responses if i spell the darn device's name right? I'll see if i can get a mod to fix the topic.
/Edit
B!
Edit
/Edit
