Cmoy -- Best way to wire a pot for ground?
post-1393342
Thread Starter
Post #1 of 12
The Monkey
Monkey See, Monkey DAC
A really sick dud
Hi, I'm buidling my 3rd cmoy, but my first using a pot. I think I understand the pinouts on the pot, but I see that two of the pins go to ground. What is the best way to wire this? Do I attach a small wire between the two ground lugs and a lead wire from one of the lugs? What's a good solution? Thanks!
post-1393424
Post #2 of 12
n_maher
Resistorous Conflagorous
TM,
I usually just bend the two pins together and run a single wire to the "virtual ground loop". You can connect all of the grounds together if you want (input, output, pot) and then run a wire to the board as well. There are lots of options. Just make sure that you connet the right pins to the right places
For me it all depends on how I have things set up and what I want the final layout ot look like. I tend to try and run as short a wire as possible, but that's just me.
HTH,
Nate
post-1393470
Post #3 of 12
The Monkey
A really sick dud
Thanks Nate, that does help. Do you happen to have any pics of a wired Alps pot?
post-1393574
Post #4 of 12
n_maher
Unfortunately I only have pics of the wired Panasonic, I've haven't found a good project for one of the RK09s yet, which I assume is the one you're talking about. Here's the panny in case it helps. Man, I forget how bad I was at soldering in the beginning
. Link to picture.
post-1394059
Post #5 of 12
Fresno Bob
@The Monkey if it's alps pot with the switch. this is the way it beleave its done
with the pot knob facing to you legs up two right side pins are the grounds
two middle pins are the outputs (to the amp) the two left pins are the inputs (to the input jacks)
Hope this helps
post-1394298
Post #7 of 12
The Monkey
A really sick dud
Thanks guys. I think I've got it now. I'll wire it up tonight and let you know how it goes.
post-1394996
Post #8 of 12
The Monkey
A really sick dud
grrr...Wiring this pot is no walk in the park. I'll need to finish tomorrow night.
post-1395016
Post #9 of 12
robzy
Once you get it done the first time though it will only take 5 minutes from then on. Its just a bit of a learning curve some times.
Rob.
post-1395024
Post #10 of 12
The Monkey
A really sick dud
Rob.
Thanks, I think you're right. I'm finding the soldering difficult with the tiny pins, but practice is the only way to get better.
post-1398584
Post #11 of 12
The Monkey
A really sick dud
Thanks for your help, everyone. I fried one pot, but the second one was much easier. Now it works! I see a Mint or Pimeta in my future...
post-1398616
Post #12 of 12
robzy
Congrats
For a MINT/PIMETA is as simple as pushing the pins of the pot through the holes and soldering them right in, no messing around with which pin is which :p
Rob.
