closed circumaural headphones better than sennheiser hd280's for between $100-$200?
post-7693569
Thread Starter
Post #1 of 17
vankilsing
Hi, I am new to the forums here so please don't destroy me xD
Anyhoos, I was looking for some good recommendations for closed circumaural headphones that are better than the sennheiser hd 280's for between $100-200.
My headphones will mostly be used for listening to music casually, however I want them to have pretty good noise canceling if possible and not leak much sound as I currently live in a dorm with two other roommates and do not want to distract them nor here their sounds thus distracting me.
Headphones that can produce good base and clear sounds are ideal.
I liked the style of the hd 280's but I want a little upgrade if possible.
Please help!!
Thanks :D
post-7693588
Post #2 of 17
MalVeauX
Heya,
THe HD280 Pro's isolate pretty well. The next step would be the Audiotechnica M50. It isolates very well. It's neutral, but can supply bass where needed, and is good enough in mids/highs too. It's neutral in general, flat. Next check out the Fischer Audio FA-003's (using leather pads for isolation).
Very best,
post-7693605
Post #3 of 17
Tacoboy
Please help!!
Thanks :D
What are the things you plug your HD-280 into now (details please)?
post-7694239
Post #4 of 17
vankilsing
Tacoboy - I will mostly be using it for listening to music from my phone/mp3 player and to music and game sounds from my computer.
Thanks everyone for the help! :D
post-7694500
Post #5 of 17
Tacoboy
What's the sound card in your computer, or is it "on-board" sound card?
post-7694757
Post #6 of 17
vankilsing
It is a stock sound card for the Lenovo X220 Tablet so I am not sure what it is...
post-7694771
Post #7 of 17
bcasey25raptor
Aka: Brycon Casey
aka mental patient
aka Enter Darkness
aka Shurefan
aka reaperofaudio
aka everyone knows
aka very funny
Generally the Shure SRH840 and the Audio Technica ATH M50 are recommended in that price range.
post-7694829
Post #8 of 17
Tacoboy
A tablet, one way to improve the sound is get an Asus Xonar U3 USB sound card ($40+).
The U3s built in headphone amplifier, will help any headphone sound better
And I'm guessing the Xonar U3 will power headphones up to about 150-Ohms
post-7694895
Post #9 of 17
Digital-Pride
I second the Shure SRH840 recommendation as you'll find it a rather nice upgrade over the HD280PRO.  Other notable options include:
Audio-Technica ATH-A700
Shure SRH440
Ultrasone HFi-580, HFi-680
post-7714108
Post #10 of 17
vankilsing
I decided to go with the audio technica m50 and the asus xonar u3 usb sound card. Thanks everyone for the help! I cant wait till they come in the mail xD
post-7715836
Post #11 of 17
HeadphoneAddict
Shure SRH840.  I thought they sounded very balanced and more transparent than I expected from closed cans.
post-7719665
Post #12 of 17
vankilsing
I just received my Audio Technica M-50's but I am having some concerns about them. My box came a bit beat up in the mail, which I didn't think posed a problem, but the item itself which was supposed to be "new in box" had some odd scratches and the metal rings on the outside of the cans seems kinda worn and one seemed like was falling off. How are the build quality usually on Audio Technica headphones usually? The sound quality seems pretty good though so I am not sure if I should be concerned with some of the outer wear of the headphones. Also, these are disappointingly not circumaural. By my understanding, circumaural go around the ear, while these simply sit on top of them.
Do the Shure SRH840 cushions go around the ear, against the skull, or on top of the ear?
Thanks for all the help everyone!
post-7719708
Post #13 of 17
Eric_C
^ Your understanding of circumaural is correct, and the M50's should be circumaural by design.
If the cushions aren't sitting around the ears for you, then it sounds like they just happen to be too small for you.
post-7719851
Post #14 of 17
bcasey25raptor
Aka: Brycon Casey
aka mental patient
aka Enter Darkness
aka Shurefan
aka reaperofaudio
aka everyone knows
aka very funny
Sounds like you possibly got a cheap knockoff. Or perhaps you got sent a used pair by mistake. Try contacting the seller and tell them the situation.
post-7719980
Post #15 of 17
Tacoboy
Someone might be trying to sell you some used headphones as new.
Other people have been sold M50s in a beat up box and used sub-quality condition.
Any chance you could tell us who sold them to you and how much you paid?
