Closed Cans -- Recommendations [$200 ~ less]
Jan 26, 2014 at 2:32 PM Thread Starter Post #1 of 25
Nihl
looking for a good pair of closed cans that can be worn for about 8hrs a day without getting uncomfortable (velvour is prefrble)
isolation and durability are also a must, price range $200 ~ or less... any recommendations?
music taste: electronica, dub, chill, indie, instrumentals
Jan 26, 2014 at 5:22 PM Post #7 of 25
The MDR 1R is my top recommendation, since its rediculously comfortable and you change the pads to velour pads. I can't think of any other competitors.
The M50 is really uncomfortable, so is the SRH 840, and UE6000.
Oh wait, forgot about the ATH A900x, K550, and DT770.
They're all comfortable, but I think the A900x sounds the best. These larger cans are also, better sounding overall than the 1r.
Jan 26, 2014 at 5:59 PM Post #8 of 25
After posting here I impulsively ordered the dt 770 on amazon. Got it with a hard case for less than $200. I considered the ATH A900x but the dt 770 is cheaper. Once I receive them I'll use them for a day at work and let you know what I think.
Jan 26, 2014 at 6:26 PM Post #9 of 25
Cool, let me know how they sound.
Hope you have the proper amping to get the most out of them! :)
Jan 27, 2014 at 9:27 AM Post #11 of 25
while I'd recommend the yamaha pro 400, I don't know I could wear it that many hours. The senn hd280 seems like it would work for hours on end without a problem and the sound was quite good.
Jan 29, 2014 at 9:56 AM Post #13 of 25
Just got the dt 770 in last night. I loved the sound (definitely warmer and bassier than my T90 but still very detailed and engaging) but there were two problems. Firstly, the left cup was actually busted. There was a very audible buzzing with bass. Secondly, these cans leak like CRAZY at even low volumes. Definitely not suited for studying in the library. They might be suitable for a louder work environment, though.
