obobskivich
the soap can, depending on what you use, and who you are, cause irritation with your skin (if you let it dry in, and then sweat/etc into the pads, it can cause some irritation/redness/etc), this assumes you use some pretty nasty detergent and are fairly sensitive to it though
as far as cleaning them, I like zorander's method, if you're paranoid, you can wash, rinse, and repeat, as far as the blow dryer goes, just keep the heat on low, remember, nothing separates a blow dryer from a heat gun except the name
and while I agree with never buying used headphones, germs aren't gonna eat your soul just because you touch them
