vladpetric
- Jul 26, 2016
Like many people, I got a Mojo in 2016 - a great sounding value DAC. After a couple of years its battery died: it could not hold charge anymore.
As replacing its battery at the local service center (New York) had an estimated cost of 130$ plus shipping, I decided instead to try operating it without a battery.
The most difficult part was finding a hex key to open it (unfortunately, I can't tell you which one it is, as I found one in my employer's maker shop, without a label). After that, removing the battery was straightforward - it really is meant to be easily replaced, once you open it.
My Mojo did work afterwards - but I soon discovered that it needs more than 1W of power, when running without a battery. With a simple Amazon-style charger it would make click sounds all the time. So I got a 5V iFi power adapter that can output 2.5W, and now the click sounds are gone, and the sound is again glorious. I'm using a Beyerdynamic DT880 / 600 Ohms headphone (not exactly an easy to drive thing).
Now my Mojo is living a second life as a nice desktop DAC. Note that it still turns itself off automatically after a while when idling, which not a big deal as far as I'm concerned
Obviously, don't do anything like this if you don't know what you're doing (don't be an electrostatically charged bull in an electronics shop ...), and it will probably void your warranty, if you still have it.
