Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12463037
Post #14,881 of 40,445
ddaktiv
Regarding the part I highlit in bold, the Mojo has the same output as the Hugo with even better distortion measurements. John and Rob have both commented how it's easy for people to think the tiny Mojo is not capable enough for full sized headphones because of its size, but it really is a very powerful piece of gear that is very capable. Made more remarkable because of it's size.
I completely agree :) I love the mojo and it's transparency, it's actually one of the reasons why I got it. Details and power are there, I'm not sure what mutes the low end though.
I've tried dap+mojo dap+mojo+amp and they're all very level sounding... My conclusion is it really does let you hear the recording very accurately as I've tried r&b w the stack and the low end is there, classical and it's there but not as dominant..
When you want to have the extended lows or an omnipresent bass layer, it can't be achieved with any mojo combination (so far haven't found a combo that does this). It's like listening to an hd800... It's there but it's not really there.
It's weird because a different story when using it w iems. There's more extension and notes are all very distinctively presented.
Mojo has enough juice to power big cans but I think when you have good bass capable cans, mojo won't satisfy your reason for buying those cans. I'm open for amp recommendations for mojo combos as I really prefer the mojo dac to my DAP's.
post-12463097
Post #14,882 of 40,445
twiceboss
Dude.. just buy a pair of extreme bass headphones. Ive seen you ask the same questions in so many threads its not funny. Want bass go for a pair of bass headphones. Geeze. Or just strap a subwoofer to your ears.
Oh come on.. read the rest of it. It solved.
What do you expect me to buy extreme bass than Th600? ... that equalify pro did So Fxxking amazing with the deep and thump bass now haha xD
Thanks for the suggestion though! :wink:
post-12463175
Post #14,883 of 40,445
Townyj
Hahaha after i replied i went through the next few pages and saw! :wink: good stuff.
post-12463183
Post #14,884 of 40,445
Rob Watts
Member of the Trade: Chord Electronics
Originally Posted by Multimediers
Just wonder if anyone here experience the same situation.
I had fully charged up my Mojo and had been using it for not more than 10 mins yesterday. When I started using it today I discovered that the power indicator went to green immediately. It seems the battery level was going down even if I am not using it. The USB power supply was being disconnected every time when the Mojo was being fully charged and the Mojo is never being used when it was being charged. The Mojo had went thru 6-7 times of complete charge-up/discharge cycles. The longest play time (continuous) which I got is not more than 5 hours (can't remember where from this thread that some others can get 8 to 10 hrs of play time).
Is my Mojo not working as expected (in terms of battery life)?
BTW, would battery life be shorter if Mojo is being used under DSD mode?
I think the clue is the fact that it starts at green - and getting five hours from green is about right. Make sure that the unit is properly charged - turn it off, and charge overnight, so that the white charging light goes out. When you power up it should be blue. If not, its possible that your charger is not capable of delivering 1A for 4 hours - what can happen is the charger gets hot inside, reduces its OP current, then Mojo will stop charging as it does not have enough voltage. So try a 2A charger for example.
The power consumed by the FPGA is 475 mW - less than a third of the power used in total. Using DSD should actually be slightly lower power, as most of the WTA DSP cores are not being used.
Rob
Reactions: onsionsi
post-12463217
Post #14,885 of 40,445
Rob Watts
This is something new for me:
I don't warm up to new music readily, yet, with Mojo, for the first time in my life, I am listening to music that is very different for me.  From a suggestion here, "Running with the Wolves" by a 20 year old Norwegian has blown me away!
As xeroian described:  I started out to 'rate' Mojo on the song ,but ended up lost in this young person's gorgeous haunting voice...losing myself (foot tapping) in the "musicality" as well as the unusual pronunciation and lyrics.  Aurora (Tidal)
I have listened to more new music in a month with Mojo than I have in 12 months without.   It has inspired both me and my wife to go into new areas.  This Norwegian singer, as the classical music of  Stravinsky are captivating me.  The detail is inescapable with Mojo; it captures me while listening.
I mention just two "new" musical experiences for me but I could just as easily add another half dozen.  One mojo reviewer cited Amber Rubarth, and I heard what he heard, and got hooked.  I have 3 of her albums and now have put in favorites 2 of Aurora albums, and a slew of Stravinsky performances, now listening to the same ballets, performed by different orchestras.
Mojo, what hath ye wrought?
What a blast!
I had a similar experience with Hugo - in that I found I was listening to much more music in general. Also, the really odd thing was that I found I could enjoy really bad 1930's recordings - now you can hear all the EQ problems and the distortion, but Hugo/Mojo allowed me to connect to the music in a profoundly different way than before.
Technically, it caused me big headaches, as I could not understand why it had this quality. I managed to fully understand it with the Dave project. It turned out to be the timing errors that digital recordings introduced - or rather the timing errors that DAC's create when it goes from sampled data back to the original continuous analogue signal. What was strange is that extremely small timing errors have a very big impact to how our brains makes sense of the music - and reducing these very small timing errors allowed me to connect with the music.
Rob
Reactions: onsionsi
post-12463371
Post #14,886 of 40,445
avesta07
Hey guys
i have Samsung Galaxy S6, i saw someone said that the Samsung DAC is quite good.
if i want to pair up with Mojo, does the improvement will be noticeable?
i need your opinion, should i buy DAP such as Fiio X5 2nd gen pair it with Mojo ? or
just stick with my galaxy S6 and buy Mojo ?
and if im going to pair it with only the s6, i also heard that it best to download UAPP apps for listening music due to limitation in samsung built in player. is it true?
for the set up itself, mostly i will use my AAW W300 for portable set up.
thank you!
post-12463381
Post #14,887 of 40,445
NPWS
Website
www.instagram.com
  Hey guys
as for the set up itself, mostly i will use my AAW W300 for portable set up.
thank you!
just stick with your s6 and buy mojo instead buying fiio x5 2nd gen pair with mojo
post-12463387
Post #14,888 of 40,445
mrback
i;ve just got an X5ii to pair with my mojo, so apples & pears really. I wanted something with big storage possibilities & to have good sound if I wanted to take out & about without the mojo. Just awaiting a cable from Vidal to test, the mojo was great with a dx50 so looking forward to hearing it with the X5ii.
post-12463459
Post #14,889 of 40,445
avesta07
oh i see,
aand also i eard that we need to use UAPP instead of the built in music player in Samsung due to some limitation, is it true?
one of my concern using the s6 is the storage and the battery consumption
would love to hear your review using  mojo + X5 ii
post-12463493
Post #14,890 of 40,445
GreenBow
I have come across a problem with a new device that I just bought, but I think it's the cable.
I bought a used DAB tuner on ebay, (with coaxial and optical outputs, as well as analogue). It's stopped working across the jack-to-phono cable that I was using for coaxial to Mojo. I had the set up working ten minutes, then switched off. When I try it again I get only a bit of crackle. The sampling rate indicator on the Mojo is flickering red. While it was running orange when it was working and playing broadcasts.
I need to get a digital cable; either coaxial or optical. I was originally thinking optical. I'd like to run the tuner through my Mojo like that from now on. However I feel I need also to test the coxial situation. Either the Mojo, the cable, or the tuner, is causing a fault.
I am not a brain-box on coaxial cables. Please can someone advise me if the liklihood of the issue is with the cable?
I imagine that Chord would have an idea of what a flickering power button means please.
post-12463503
Post #14,891 of 40,445
masterpfa
I would imagine the connection is intermittent hence the sync is also intermittent and the flashing power light. Probably due to a defective cable
I experienced the same with an optical Toslink to Mini Toslink. Replaced the cable problem gone.
post-12463513
Post #14,892 of 40,445
GreenBow
OK, thank you. I am probably zooming into town today so I will have a look at cables.
post-12463528
Post #14,893 of 40,445
Ike1985
What did you change to get double and quad rate DSD to play without skipping? What iPhone are you using?
I get DSD in both formats to play fine on my iphone 5 running Onkyo and my S7 edge running UAPP.  I don't have a lot of stuff running in the background though, never experienced stuttering, not once.
post-12463554
Post #14,894 of 40,445
Ike1985
  Hey guys
thank you!
If you're transferring via USB there will be no difference.  If you use the S6 then you can use apps like youtube, bandcamp, spotify, tune-in, tidal, etc.
post-12463558
Post #14,895 of 40,445
Ike1985
  oh i see,
Why not go S7, tmobile and AT&T and euro carriers are literally givinv them away, seriously.  It's Buy-one-get-one free, you buy one, you sell the other to pay off the first and you've got a free s7 or s7edge.  Plus the S7 series has micro SD card support which is huge for audiophiles.  PLus you get a free gear VR virtual reality. =P  However, you should know that apple products are better suited for DACs because they can output audio from all your favorite apps like bandcamp, tidal, etc directly to mojo bypassing the built-in dac thus preventing unnecessary sampling which lowers sound quality.  Android can only pass tidal and actual albums you own on your hard drive to mojo without upsampling, everything else will be upsampled by the native upsampling on android and sound bad.
Users Who Are Viewing This Thread (Users: 1, Guests: 8)
