Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12459540
Post #14,731 of 40,464
warrior1975
Anyone have an issue with their usb port? The data port. I tried connecting the Mojo just now to my cell, worked the other night, not now. Tried with my Note 8,no good. Tried different cables, nothing. Also tried using the otg cable and it work on a different device.
No light on the power button, likes it's not receving a signal. Any suggestions? Don't have another otg cable, but that doesn't appear to be the problem. Don't have a dig coax yet either.
post-12459548
Post #14,732 of 40,464
Wyd4
Country Victoria, Australia
Hey mate.
Don't know if you are using usb audio player pro or not. But try installing the demo and see if it will find the device.
I had issues with my Samsung tablet and native support for any dac.
Other than that. You did it is working with another device so I don't think it will be the mojo its self. Short of rebooting. Force closing apps. Unplug and replug. I don't really have any golden answer unfortunately.
post-12459552
Post #14,733 of 40,464
warrior1975
It worked Saturday night on my phone... Haven't changed a thing. Really odd. I put it on charge for now, maybe it will reset itself or some crazy electrical magic. I'll TRY UAPP too. :sob::sob::sob:
UAPP doesn't have a trial player anymore?
Ok... I hooked the USB up to my mac, just to test to see if the light went on and it did. Must be the otg cable. I don't get audio through the Mac, but I need a cck. Just wanted to test and see if it would connect.
Opinions?
post-12459590
Post #14,734 of 40,464
captblaze
Blazin it up in the land of Lincoln
Opinions?
I always have an opinion, and since you asked...
USB is the way to get the highest resolution #s of all the inputs, but is horrible in its restrictions (driver, cable spec). Optical get the jitters, but for short runs perhaps not and digital coax is also cable sensitive.
this why super expensive DAPs offer all of the 3, or any combination of the 3 whereas a mobile  phone gives you one choice and it is as fickle as the hot girl you drooled over in high school but couldn't get anywhere with her
moral of the story... time for a new OTG cable and don't make it a cheap knock off
post-12459595
Post #14,735 of 40,464
warrior1975
It's a brand new cable. Literally bought it Saturday. Lol. I'm going to order a better one online. Going to bestbuy to get a 3.5 dig cable for now.
post-12459602
Post #14,736 of 40,464
Wyd4
LOL
Love it.
Though I married the hot girl I drooled over in highschool and I have had no issues with USB from android phone or iPhone.  Perhaps I am just lucky :p
post-12459614
Post #14,737 of 40,464
warrior1975
Lol... Sounds like you are. I have 9 minutes to get to best buy... Fml. Stuck at a light. Plus, they probably won't have it even though they said they did.
post-12459643
Post #14,738 of 40,464
Vigrith
Pretty normal for Dignis. Better than the AK cases.
Now I'm torn, that case is beautiful actually, I want one of those, shame I'd get rammed by VAT considering it's from outside Europe. Looks so good though.
post-12459659
Post #14,739 of 40,464
Townyj
Well, just tested my set ups, the mojo using poweramp then same song using uapp. I kept the headphones the same just switched to my sabre hifimediy android dac and cayin c5....
Mojo - still got the issue of stuttering etc on both poweramp and uapp. Uapp playing back red on mojo and poweramp on blue due to android upsampling.
Sabre android hifimediy dac and cayin c5 - poweramp played without a single stutter and uapp still stuttered.
Ive read the posts and links about uapp. I've played with the settings and never could eliminate the audio stutter etc.
Sound differences ?... literally sound more or less exactly the same. Theres zero chance of me picking out the mojo to my android dac and c5 amp in a blind test based on sound quality. Something is wrong, cos £400 needs to explain itself. As i said the mojo stutters in poweramp yet my original set up plays it fine. Theres NO difference between tidal HIFI streaming compared to the same song on poweramp in mp3 format.
My original setup sounded fine, I didnt expect it to blow me away but I did expect a fair improvement for £400 plus the rave reviews.
I genuinely feel as though im not using it correctly considering the mojo sounds the same as my £30 android dac and c5 amp. Surely tidal HIFI of purple rain will sound better than my 320kbps mp3 download... ?
If this is as good as mojo gets and thats what £1000+ dacs sound like, im gutted considering the sabre android and cayin c5 cost me £140.
Hmmmm....
When i owned my X2 headphones it was night and day difference between my phone and mojo/concero hp. The phone sounded less controlled throughout. You need to remember that sometimes there isnt a massive gain, the mojo doesnt seem to jump out instantly. You obviously dont hear it or feel like its worth it. Sometimes wonder why i forked out $900 on the little thing. My new headphones sound pretty good straight out of my phone. Go figure.
post-12459677
Post #14,740 of 40,464
x RELIC x
The West Coast, Canada
/snip
Hmmmm....
Well, the Crossfade isn't exactly a top tier headphone. At his level you need to have a transducer (headphone/IEM) that can keep up. I know, cliche, but it's true.
post-12459694
Post #14,741 of 40,464
warrior1975
esm87 I couldn't pick then out blind either. Lgv10 and C5. That being said, I'm enjoying the music more. Not sure why as I ab I hear the same. Either way, mojo sounds better to me, oddly. I'm not happy I can't use it now to work tonight.. Many damn it all, I can't because I've my cheap ass usb other cable.
post-12459706
Post #14,742 of 40,464
esm87
I have a feeling that a £400 investment in a pair of IEM's or stretch to the se846 would give me a far, far bigger audio upgrade.... or Im using the mojo wrong, i've convinced myself I dont know how to use it properly. I mean, theres no way that a cheap android dac with a cayin c5 amp playing mp3 downloads of 128 to 320 kbps on poweramp, could sound identical to mojo streaming tidal HIFI. Given, Im not using TOTL headphones (v moda crossfade wireless/sony ex650 iem/psb m4u2) but they aint exactly terrible, compared to the average joes apple ear buds my headphones are leagues above.
Gutted nvm...
post-12459715
Post #14,743 of 40,464
warrior1975
Bro, don't be surprised. I've owned lots of nice audio gear, and some things, I couldn't hear a difference, especially the electronics. Headphones or IEMS, different story. Daps, dacs, and amps all sound similar to me generally speaking. I could tell the difference between my Fiio X1 and my AK240... Easy. But my AK240 and ak120ii, not a chance, not even between my AK240 and ak100ii. Zero. Hell, my girls ipod 5g touch I could barely hear a difference, and I'm not convinced I really could. The damn thing sounded amazing to me. Then again, I've said I have the worst ears here... Might very well be true.
I'm definitely keeping the Mojo. Just because. :wink:
post-12459716
Post #14,744 of 40,464
esm87
I totally understand where your coming from. The psb m4u2 are fairly respected at their price point, more so than the crossfade wireless, still... exact same sound. If anything, my old setup is superior due to zero sound stutter etc in any audio app.
Where does the entry level start for headphones to actually be impressed by the mojo?
post-12459717
Post #14,745 of 40,464
x RELIC x
Gutted nvm...
Your headphones aren't garbage by any stretch, and your approach is fairly realistic. I suggest you read Rob's blog post on the subject of listening to help understand a little more about where some shortcomings may be happening in your listening experience, or at least to add a different perspective.
I'll link it again in case you missed it.
http://www.head-fi.org/t/800264/watts-up#post_12457933
Users Who Are Viewing This Thread (Users: 1, Guests: 11)
