- Feb 11, 2008
No, but if you check post #3, you'll find the correct cables under the 'Connecting Mojo to Sony Devices' section
Firstly, you will need a Sony WMC-NWH10 cable: (there's currently one for sale, in the classifieds section, or you can order from Amazon)
and then you will need a male-USB-to-male-Micro-USB cable, to go in between the WMC-NWH10 and Mojo (the male-USB-to-male-Micro-USB cable is already supplied, in the box, with Mojo).
Here, you can see the exact same cables in use, when I hooked-up a ZX1 to a Hugo:
There are some 3rd-party unofficial cables which may get the job done, with just one cable instead of the above two, but I cannot verify whether they are reliable or not, so please do your own research before buying!
This is what I did but it didn't work with my SAmsung S7 Edge phone.
I thought we have to use an OTG cable?
No, there is a little confusion!
The above solution that I outlined is specifically for Sony DAPs.
For Samsung phones, yes, you do need an OTG cable.
