Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
949 950 951 952 953 954 955 956 957 958
960 961 962 963 964 965 966 967 968 969
  1. Mython Contributor
    [​IMG]
    Peter Hyatt likes this.
  2. Light - Man
    Originally Posted by Duncan [​IMG]
    Don't even go there, had a short phase of getting "odd" USB cables, colour changing, light chasing etc...
    Crazy what you can get these days!
    I still think hand on heart that I prefer the mojo to the Hugo, a much more <mini>"me" sound.
    [​IMG]
    Mython likes this.
  3. NaiveSound
    I'm.just super exited for that SD transport attachment, can you guys imagine the synergy (I would think it's good)
  4. VGoghs earfrmsc
    How is it known, how long the battery lasts, or how many recycles it can take before its demise?
    Surely this can only be an estimate [which are usually exagerations anyway] not fact.The device may fail to work long before the 10 years or 5000 recycles is reached. Perhaps a better guide would be how long before the line out voltage of 3 volts RMS, is no longer attainable.
    Having said that, the fact that 100000 people per month maybe more, will be sending their Mojo back to chord to have the battery replaced is a worrying scenario. With modules making the Mojo updateable,and [has anyone heard of a Mojo falure yet] it seems a reliable product so far, there will be plenty around even if only for desktop use, as miniturisation will reduce the Mojo to a watch sized device by then.
    Anyway i'm sure Chord will have forseen these events in their plans to take over the world and will reassure us that they have contingencies in place to deal with it.
    Hey slaphead, bet you you cant do a 20 minute analysis only session with the Mojo, thats 20 mins now, no enjoying it now, just analysis
  5. esm87
    Just picked the mojo up from a store but the store didnt stock the OTG usb cable to connect to my s6 edge for playback. Does anyone know if the usb connecting cable that comes with a cayin c5 works as an OTG cable?? Thought Id ask, struggling to find an OTG cable in a shop
  6. Ike1985
    To all those experiencing significant emi/rf issues, get yourself some ferrite devices-you can find them on old cables on your house. You really have to play with the positioning of the devices yo get them to work right. Ive always had atrocious interference that is way louder than the music, but now i seem to have found a placement that eliminates most of it. You need to place the largest one as close to mojo as you can get, wrapping the chord through it several times.
    Cant seem to upload a pic with my s7 edge.
  7. audi0nick128
    Seems like Mr. Darko knows more about the way more existing second module...
    Quote :
    'My hands are tied. What I can tell you is this more functionally diverse module will obviate the need for any physical connection between smartphone and Mojo but also further cement the Mojo’s present position as the number one goto DAC for two-channel rigs below a grand.
    ‘Game changer’ is an overused phrase that borders on cliché but this second module promises to be exactly that. '
    End Quote.
    So any hackers present wanna help to untie his hands?
  8. Mython Contributor
    John Franks has, himself, discussed the forthcoming modules:
    https://youtu.be/DTWcKLI0g7c?t=27m56s
    (Darko is clearly referring to the Bluetooth module)
  9. almarti
    Is it possible I am getting a better sound quality and experience with W7+foobar2000+Mojo+HD600 than W7+foobar2000+SchiitModi2+SchiitAgard2+HD600?
    If I am not fool and that's true, what to change? The Modi 2 or the Asgard 2? Or both?
    Thanks.
  10. Ike1985
    Only if one of them is sampling instead of transmitting bit perfect.
  11. esm87
    Will any micro to micro work for connecting this to my s6 edge? Got the mojo but not the cable
  12. betula
    It is possible.
    In my opinion you can sell the Modi 2.
    Check if you prefer Mojo to Asgard 2, or Mojo on its own.
    If you prefer Mojo on its own, you can sell Asgard 2 as well.
  13. Mython Contributor
    No, it must be an OTG cable (as opposed to a standard data or charging cable)
    Look in Post #3 for more info
  14. audi0nick128
    Thanks for the link... Will check it out.
    Yeah right Bluetooth makes sense...although I don't like it... But maybe it's APTX MQA :)
    But what could be behind the cementing of mojo s position in a 2 channel system?
  15. esm87
    Anybody care to link me to a uk micro usb otg cable please. Cant seem to find what Im after, only result I can see is a 2metre cable and a lindy cable thats got terrible reviews??
