korotnam
- Oct 1, 2015
Yes.
To clarify, I am unfamiliar what optimal volume control would be when double amping with the Mojo (although I do understand that the Mojo is not really an "amplifier").
Yes.
Mojo draws around 1A while charging, so any charger above 1A should be fine. Best to have 1.5A+ charger, because some chargers claim higher than the actual output.
Higher current charger generally doesn't hurt. Mojo will only draw as much current as it needs to start charging.
In which case, what is considered optimal? Seeing as in most situations you would want an application's volume controls maxed out and leave volume modulation to the amplifier.
I'd probably set it to line level in this scenario then it acts as a preamp.
Yes, in most situations. The Mojo doesn't use op-amps and it's analogue output it's exceedingly clean, so you don't need to worry at all about double amping because there are no op-amps in the signal path anyway. With the exceptional noise performance of the DAC Rob is able to use very few discrete components on the analogue output. Think of it as full time variable line out, and a measurably better signal than many 'conventional' line out configurations.
If you hold down both volume buttons when you power on the device it will set a shortcut to 3V output (nothing is bypassed, it's just a shortcut to that volume). From there you can press the volume down button four times to 1.9V output, which is close to the standard 2.0V.
Optimal would be whatever level is optimal for the input on the amp you are connecting It to !
I'm using a 1.67A charger
I thought for a $600 DAC / Amp should have come with its own Charger.
can we sue the DAC Amp while charging by a desktop? I did that with my E17K
Nice just saw this post thread is moving fast. Can you test it on a 2.1a charger and see how much its drawing?
Guys, I just wonder, if there any other option to get amp dac for $600 range. Minus the portability. I mean amp dac $600 desktop setup which is better than Mojo.
If yes, tell me. I really lack of amp dac knowledge. Cuz i just ordered Mojo and idk whether I will use it portable or just sit at my desktop only. (i can return it if there any other better $600 desktop setup)
Thanks!
Yea I'm wondering about the same thing. Is there a Desktop DAC / Amp in the Mojo price range that is as good as the Mojo but for Desktop use instead of Portable?
if it is as good as... I dont care much.
I just wanna know if there is BETTER than it. Cuz i wanna maximize the potential !!!
