Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12294666
Post #10,216 of 40,442
AudioBear
  Well yah. and beyond not being able to answer calls is not easily being able to select songs via touch screen.  I'm fairly active with DJ'ing my music while listening since I'll get the itch after listening to a particular track for something else while hearing what I am listening to.  The digital age!  But yes I have used velcro.  But the problem there is its either too strong or a bit scarily weak.
Neil
I'm more passive.  I use playlists and go with them.  Like I said most people won't like my solution.
post-12294670
Post #10,217 of 40,442
hitman1
Hello:
I have the right charger now doing 2 amps or better and i am fully charged. I have Flak, DSD and MP3. I thought using the Onkyo App depending which of these files I play the power light would give me a steady color? I play DSD, Flak and MP3 and my power light always stay at blue? Shouldn't it be white when I play a DSD?
post-12294674
Post #10,218 of 40,442
kenman345
Anyone got the pinouts for the DX80 and the mojo? I thought I had seen it but cannot find it through any searches through this thread or the official DX80 thread.
post-12294677
Post #10,219 of 40,442
NaiveSound
What u mean pinouts?
post-12294679
Post #10,220 of 40,442
NaiveSound
Cost effective and best thing are opposing conditions. Moon Audio has both coax and Toslink cables that would meet your needs in the $75 to $100 price range. They are 6 inch cables with straight plugs while your Fiio cable is about 4 inches with right angle plugs. Your cable was designed for an analog signal, but could work since it is a sheathed cable but not a 75 ohm coax cable.
Not sure what problem you are trying to fix, but replacing your $14 cable with something almost as short will cost a lot more. If interested, contact Moon Audio (forum sponsor) and ask them if he can put right angle connectors on the coax cable.
Thank you, I wish I could find a traditional coax cable the length I need with a right angle set up, I guess I'm surprised these aren't readily available
post-12294686
Post #10,222 of 40,442
kenman345
post-12294691
Post #10,223 of 40,442
x RELIC x
The West Coast, Canada
post-12294694
Post #10,224 of 40,442
Danthrax
How do I pay for things from taobao the entire site is in a different language and won't translate properly via google translate...
post-12294698
Post #10,225 of 40,442
lukeap69
It's a struggle I can tell you. I don't know how I managed to do it... in many tries though.
post-12294714
Post #10,226 of 40,442
rkt31
hi all, i am likely to receive the mojo in few days. i have fiio3 2nd gen and know the connections at fiio end which require the 4 pole trrs connector. what i don't know about the connections at mojo end in 2 pole connector. pls inbox as i am not able to check the forum regularly so the reply might be lost in this huge thread. thanks !
post-12294741
Post #10,227 of 40,442
AudioBear
Google is your friend....http://www.engtaobao.com look around there may be more
post-12294783
Post #10,228 of 40,442
doofalb
Neil
Silicone bicycle straps were suggested a while back. That or similar should work:
http://www.head-fi.org/t/784602/chord-mojo-the-official-thread-please-read-the-3rd-post/3000#post_12034620
post-12294927
Post #10,229 of 40,442
masterpfa
Hello:
This will have something to do with the settings (confession I do not use Onkyo HF Player so not certain of the setup)
Some apps have up and down sampling, which it appears your app may be set to do. These need to be removed in the settings, also regarding DSD (hopefully an Onkyo user can help here!) I believe in the setting this will need to be setup so that DSD is set for DOP.
I personally use UAPP so the settings are all different to Onkyo
Users Who Are Viewing This Thread (Users: 2, Guests: 17)
