Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
670 671 672 673 674 675 676 677 678 679
681 682 683 684 685 686 687 688 689 690
  1. xeroian
    No, not at all. To me Hugo sounds much more airy and handles female vocals much better than Mojo. I am currently listening to Chvrches Every Open Eye in high res and Hugo wins hands down. FYI - Headphones are Audeze LCD-XC.
    sonickarma likes this.
  2. Pokersound
    Thank you vapman.
    I will leave it at home charging.
    Could I use a galaxy S5 charger to do the work?
  3. raelamb
    Can anybody attest to the fact that the official 9.2.1 upgrade works okay with Mojo ?
    Haven't done it yet.
  4. vapman
    sure! any wall charger should do. nearly every smartphone charger will put out at least 1 amp, so it is good.
  5. JamesKH
    Confirmed. Having no problems at all with 9.2 1
  6. rwelles
    +1, works fine with my Mojo also.
  7. okplayer
    Update....I couldnt get the neutron music player with samsung note 3 to output high res files to chord mojo successfully (played at 44.1 only) ......thanks to the rec here got the ubs pro app for the samsung and within 10 minutes I got high res. files.....yay
    masterpfa likes this.
  8. rmullins08
    At long last got my Nexus 6P hooked up and working with the Mojo
    http://www.monoprice.com/product?c_id=103&cp_id=10303&cs_id=1030319&p_id=13013&seq=1&format=2&AID=11051853&PID=6146845&ref=cj&utm_source=cj&utm_medium=11051853&utm_term=VigLink-2470763 did the trick
    Tried a few different adapters previously which didn't work
    http://www.amazon.com/gp/product/B0151RKYBG?psc=1&redirect=true&ref_=oh_aui_detailpage_o08_s00
    http://www.amazon.com/gp/product/B015H6YUHK?psc=1&redirect=true&ref_=oh_aui_detailpage_o08_s00
  9. NaiveSound
    Where can I find a short cable (used for stacking) for coax to Toslink
    Short enough to do this
  10. mscott58
    Have to go either coax to coax or toslink to toslink. Which were you looking for?
  11. NaiveSound
    Whatever connects my dx80 to mojo, preferred (coax) in dx80 to (toslink) mojo.
    But short
    I currently have this
    But it's not a real coax and I've tested it with real coax and it's much better in sound quality, of course usb out of dap is better but dx80 doesn't support it.
  12. x RELIC x Contributor
    Do you really want to do this? I mean, why not just get a proper coaxial cable or a proper optical cable instead of adding a converter. Makes no sense to me to add this to the stack..
    There is no other way as optical is literally pulses of light and coaxial is not.
  13. NaiveSound
    I guess I'm not understanding, I just want the best possible way of connecting my dx80 to the Mojo
    But not with this
    And I need it short enough to be able to stack the devices together, as seen in the pictures above,
    The length can be the same as the fiio cable
    Please help
  14. x RELIC x Contributor
    NaiveSound, you asked how to output coaxial from the dx80 to the optical input of the Mojo. Not possible without a converter box. You are going to have to pick an output type and buy a proper coaxial cable or optical cable.
    I know Moon Audio sells the proper coaxial cable and optical cable. Also, Sysconcept sells custom optical cables.
  15. Bighappy
