Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12280406
Post #9,871 of 40,379
simonm
Has anybody found that the balls sometimes stick in place and won't click? The volume down ball is fine, it rotates without any force, but volume up and power are stiff and sometimes I need to rotate them with a little bit of force before they become clickable again.
My balls rotate freely and don't stick. lol  That's how they should be I presume.
If you have computer screen or lens cleaner try giving them a good clean and polish (with the unit off of course) and dry.  The manual says you can use Windex but that sounds a bit harsh (I'm protective of all my electronics).
If you still find they're sticky I think you should get it serviced or replaced.  You don't want the volume up ball to stick and blow out some nice earphones.
Reactions: fluidz
post-12280505
Post #9,872 of 40,379
fluidz
Uk
Uk
Thanks.  I used window cleaner on a cloth and now they're moving much more freely.
post-12280522
Post #9,873 of 40,379
yoyorast10
Is it normal that the volume down ball doesn't rotate as easily a the other balls?
Also, on the outside of the balls, it looks like there's dirt on it or something. Is this normal?
post-12280580
Post #9,874 of 40,379
Mojo ideas
John Franks
Sponsor: Chord Electronics
Some time some foriegn material might get into the gap surrounding the ball. Try rotating the ball for a few minutes the ball should become free.
post-12280591
Post #9,875 of 40,379
howdy
Minnesota
Minnesota
Is there anything underneath the ball to restrict debris from getting in the internals?
post-12280628
Post #9,876 of 40,379
fluidz
Uk
Uk
With the included micro usb cable it's loose at the Mojo side and loses connection with my phone if the cable is nudged slightly up or down, only a gentle nudge is required to make it lose connection.
I connected a couple of other micro usb cables which seem a bit better and require more of a nudge to break the connection but it still happens.
Not ideal if strapping it to my phone.  Is anybody else experiencing this? Do I have a defective unit?
post-12280713
Post #9,877 of 40,379
Mojo ideas
John Franks
The switches are sealed to IP67 standard
post-12280758
Post #9,879 of 40,379
nmatheis
GreenBow: Interesting that you pointed out the 0.5 second mute isn't consistent. While I didn't notice that while using Mojo + iPhone during my week long audition period, I do find the same inconsistency in applying the 0.5 second mute applies to the Soundaware Esther DAP I just reviewed. The 0.5 second mute should only happen in that DAP when switching between resolution, but it sometimes occurs between songs with the same resolution. Not sure why. I just mention it because it sounds similar. Sorry if it's too OT.
post-12280789
Post #9,880 of 40,379
lurk
Mine does, but it's coax jack on the Mojo, the port is not loose (no play) when the 3.5mm is plugged in, but still same thing happens as in your video when i judge the cable
  facing an issue here, not sure if it's covered under warranty
I use my mojo/dap stacks as portable, they are kept in my messenger bag while commuting
recently i notice the sound is breaking up whenever there is movement
i hv checked with several cables and able to pinpoint it to the mojo coax jack, when I twist the cable around while plugged in, the sounds breaks (power button light on the mojo flickers)
it does not happen on the X5 coax out jack. I hv tried switching both ends/3 cable types
mojo > fiio L17 > X5
being a portable, I kinda expect the L17 will be 'pushed' around a bit while in my bag
post-12280860
Post #9,881 of 40,379
betula
U.K.
U.K.
My factory cable did the same, however I didn't experience any problem with other usb cables. So in my case the factory cable was defective.
post-12280864
Post #9,882 of 40,379
audi0nick128
Northern Germany
Northern Germany
Hey there,
I am planing to get rid of the smartphone as primary source, therefore I am going to build a Raspberry Pi 2 Streamer running Music Demon Player.
Has somebody tried this combination with mojo before?
Cheers
post-12281022
Post #9,883 of 40,379
SLCanhead
  Try charging overnight with the unit off. The charging circuit looks at the state of the battery before charging. If the battery has a very low voltage, it will trickle charge the battery until it gets to a safe voltage, and then full charge will commence. This trickle charge mode can take several hours, and it is done for safety reasons, and it will appear that the battery is not working as the trickle charge mode takes some time. When in this mode Mojo must be off.
When charging make sure the battery light is white and not flashing - if it flashes, pull out the charging cable, count to ten, re-attach the charging cable. If it continues to flash, it is most likely the charger is not giving 1A at 5V, so use a better charger.
Rob
  Thanks much for the response Rob. I will give it one more shot.
I have it charging again. The battery light is white and not flashing. The unit is off (as it won't stay on anyhow) and I will let it go overnight. I am just concerned due to the fact I let it charge for about 12 hours last time. Hopefully, it was just in a trickle charge mode as you mention.
If it's somehow stuck with the power on, please let me know what I can do to check. I just don't think so being that it won't power on without the cable in, as if the battery has zero charge (and I have not held the power button after plugging the charger, to power it on.)
I charged it overnight using a charger that is 1A 5V charger, per what I was informed. It was solid white light last night, checking multiple times before bed, but was blinking as of this morning when I woke up.
I am using another charger (3rd different one, 1A 5V rated per my understanding) and it's solid light again, and has been like that for the past hour.
I also purchased another charger and cable, and will revert to that as a "final option" if this doesn't work. The store rep said it's solid quality. I will have tried 4 different chargers and 4 different cables including the newest one, at that point. All of the chargers used (except the one I just purchased) have charged other devices without issue. I understand that the Mojo has particular charging device/power requirements, so I am doing my best to adhere to them.
post-12281023
Post #9,884 of 40,379
Staxton
Hey there,
Cheers
I've been using the Mojo with a Raspberry Pi 2 (using RuneAudio, which is based on the Music Player Daemon), the Banana Pro (using MPD and the Gnome Music Player Client), and a Cubietruck (with RuneAudio), and the Mojo sounded great with all of them. I been trying these low power boards because I can attach USB (on the Raspberry Pi) or SATA drives (on the Banana Pro and the Cubietruck) to them for more storage than I can get on a phone.
Best,
Rod
Users Who Are Viewing This Thread (Users: 1, Guests: 16)
