Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
645 646 647 648 649 650 651 652 653 654
656 657 658 659 660 661 662 663 664 665
  1. joshuachew
    http://m.blog.naver.com/dignis/220605322035
  2. Ra97oR
    That is a real sexy and slick case for the Mojo.
    Deftone and NaiveSound like this.
  3. Beolab
    So a Apple Travel Charger 1A with a good cable is a good option then?
  4. lukeap69
    It does look nice. I like it.
  5. Ra97oR
    It is not as good as my Anker charger, but if you have one handy already you can't really go wrong with it. The difference is minor and only noticeable if you have the Mojo on your head or something. :wink:
  6. elnero
  7. joshuachew
    Should be available in March. It'll be sold by Dignis and they ship worldwide
  8. masterpfa
    Try the Chord Mojo Issue thread highlighted above or post the same query there.
  9. yoyorast10
    The USB cable you get with it is really short, does using an usb extension cable affect the sq?
  10. lukeap69
    Nice. March is just more than a month away. :)
  11. masterpfa
    Not that I have noticed. I have used with a 0.5M and 1M cable
  12. yoyorast10
    So I can basically just use any micro usb to usb cable? ones that are used for smartphones for example?
    masterpfa likes this.
  13. Ra97oR
    Yes, sound quality should not be affected.
  14. NaiveSound
    Other then the dignis case, is there any others? Are*
  15. joshuachew
    Not that I know of
