Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12274281
Post #9,721 of 40,442
music4mhell
  It is always better to give Mojo bit perfect files and let Mojo do the work, as the processing within Mojo is much more complex and sophisticated than a mobile or PC.
So when you have an app that has a volume control, and no bit perfect setting, then set it to full volume on the app on the assumption that this will keep the data closer to the original file.
The volume control function on Mojo is much more sophisticated than the PC as I employ noise shaping and I do the function at a very high internal sample rate. Hopefully using the volume set to max on the app will mean the volume coefficient is 1.0000000... so it will return the original data.
Rob
Thanks a lott Rob.
I am very lucky to get your reply on my query.
Thanks for such a wonderful product. This thing has truly changed the whole DAC industry.
Reactions: pytter and salla45
post-12274291
Post #9,722 of 40,442
Rob Watts
Member of the Trade: Chord Electronics
Very good info tht should be added to FAQ!
Volume control on mojo, other volume should be maxed out.
I wanted to ask a similar question but for the Hugo instead. Can I assume same settings applies?
Thanks Rob/Chord
Yes. Fingers crossed on whether the app has digital gain! Hopefully max = 1.0000..
post-12274306
Post #9,723 of 40,442
music4mhell
Thanks Rob/Chord
Now this is tricky, if one app has the digital gain > 1.0000, then that's not a very good input for Mojo(it will contain distortions).
How do we know if at max. volume the app has the digital gain <= 1.0000 ?
post-12274312
Post #9,724 of 40,442
NaiveSound
I'm also curious about this, about to read up on the Android player thread, but also, what do you guys have experience with?
post-12274316
Post #9,725 of 40,442
lurk
Tht I think you will need to ask the manufacturer/developer of the app in particular and pray they are as responsive as Chord. :grinning:
post-12274357
Post #9,726 of 40,442
Rob Watts
You can always do a listening test. If set to max against 50% say, and it hardens up (becomes brighter) with loud recordings then its clipping. If on the other hand the perception of sound-stage depth is reduced, then the volume control is degrading the sound.
If you do that test and can hear no difference then don't worry, its a good app volume control.
Rob
PS for fun I just did a very quick test using Dave. I listen to radio 3 using the BBC iPlayer. I normally have it set to max. I reduced the iPlayer volume control to half, boosted Dave volume control by +6dB - and yes I felt sound-stage depth was worse with lower iPlayer volume.
post-12274437
Post #9,727 of 40,442
Fukuoka, Japan
Fukuoka, Japan
Website
www.hear.reviews
I've added two of Rob's posts about the volume control to the FAQ
Reactions: Mython and sabloke
post-12274439
Post #9,728 of 40,442
EllieFreckles
I don't have anywhere near me that has this to test. But I'm seriously considering getting this for my HD800. Think I'll order this off Moon Audio, as I can't find any other retailer I know that is selling it, and that has it in stock. I currently have a Lyr/E17 set up. I'm saving up for a better set up for my HD800, but that will be a couple years. With all the reviews and impressions, I'm honestly excited to see how this pairs.
post-12274449
Post #9,729 of 40,442
betula
U.K.
U.K.
Given that you still hear music with the dx80 volume at zero then it would be bypassing the volume control completely (like most DAP's digital output). No need to adjust the volume on the dx80 I believe. As per Rob's post above, if you can adjust the volume on digital output then you should maximize it.
You are right. DX80 has fixed outputs. Doesn't matter, what the volume setting is if you use lo or digital out.
post-12274452
Post #9,730 of 40,442
betula
U.K.
U.K.
I've been feeding my beloved mojo from A dx80 (it's a dap) via coaxial, but I've always had the dx80 volume on 0 and only controlled the volume on my mojo.
When I use my android note 5 I have to have the volume midway and still control volume with mojo, should I turn both dx80 and note 5 volume on max and then also control volume on mojo?
What is the best way, for the best possible sound. For both the Dx80 and note 5
Do you notice any difference in sound when you hook up mojo with dx80 or note5?
post-12274505
Post #9,731 of 40,442
ezphoto
Can anyone tell me how come I only have 32bit on my Macbook Pro? Which one do I choose?
post-12274520
Post #9,732 of 40,442
x RELIC x
The West Coast, Canada
32bit is the highest bit depth available, you can't change it as its only a display of the max bit depth.
To the Mojo you typically want to have the Sampling Rate to be what the file's Sampling Rate is or else the computer will up/down sample if all your files aren't the same sampling rate. For example, if you only have all lossy files like MP3 and AAC or cd rips then you want to set the sampling rate to 44.1 and there will be no up/down sampling at all. If you have a mix of high resolution files and lossy and cd quality then one of them will be up/down sampled depending on the sampling rate you choose. Of course the music will still play with pretty much any sampling rate you choose, but it's not optimal with the Mojo.
The best solution is to purchase a third party software like Audirvana+ that will output the sampling rate native to the file you are playing.
post-12274558
Post #9,733 of 40,442
ezphoto
Thanks. I'll try give it a try.
post-12274579
Post #9,734 of 40,442
masterpfa
I am giving the numbers randomly just to normalize the output volume in different scenarios.
So, will there be any difference in sound output ?
EDIT:
having read Rob Watts reply edited existing post.
Now to try for myself.
post-12274582
Post #9,735 of 40,442
Pier-Fi
@ezphoto
JRiver has variable sample rate as well, so does Vox, which is free but not as good as Audirvana and JRiver. BitPerfect and PureMusic are additional contenders. They work alongside iTunes.
cheers,
Pierre
Users Who Are Viewing This Thread (Users: 2, Guests: 23)
