Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12273929
Post #9,707 of 40,299
Raketen
post-12273964
Post #9,708 of 40,299
x RELIC x
The West Coast, Canada
Finally sitting down with my HE-X and Mojo (last night was spent mostly charging it for the first time :p ) through my iPad Air and Tidal and I am gobsmacked! Can't believe the SQ from a $599 device! And the ability to take this sound with me to work and have this type of sound quality is simply amazing!
Yup. As Chord has said.... Game changer.
Reactions: headmanPL
post-12273965
Post #9,709 of 40,299
x RELIC x
post-12273966
Post #9,710 of 40,299
MacedonianHero
Headphone.Guru Editor
Toronto, Canada
Toronto, Canada
post-12273967
Post #9,711 of 40,299
Ra97oR
CanJam London 2016 Karting Champion
Hey guys, I am having a small doubt.
While playing through my Android mobile(Oneplus one) to MOJO.
Should i put the max. volume in mobile and control the volume from Mojo.
Will there be any difference in quality, if i won't use max. volume from my mobile and match up according to Mojo's volume.
Let me give the example :
Mob Vol(100%) + Mojo Vol(50%) --> X db (Y mw)
Mob Vol(75%) + Mojo Vol(75%)  ---> X db (Y mw)
I am giving the numbers randomly just to normalize the output volume in different scenarios.
So, will there be any difference in sound output ?
I would recommend trying apps like USB Audio Player Pro, Onkyo player, etc. Using player designed with USB DAC in mind will give you better sound quality and no unnecessary resampling.
post-12273976
Post #9,713 of 40,299
MacedonianHero
Toronto, Canada
Toronto, Canada
post-12273990
Post #9,715 of 40,299
music4mhell
I can't use these Apps, i dont rely upon my own collection of FLACS, i use an app which is equivalent to Spotify in India.
So my question remains the same, will there be any difference in SQ in above scenarios.
Thanks.
post-12274209
Post #9,716 of 40,299
It is always better to give Mojo bit perfect files and let Mojo do the work, as the processing within Mojo is much more complex and sophisticated than a mobile or PC.
So when you have an app that has a volume control, and no bit perfect setting, then set it to full volume on the app on the assumption that this will keep the data closer to the original file.
The volume control function on Mojo is much more sophisticated than the PC as I employ noise shaping and I do the function at a very high internal sample rate. Hopefully using the volume set to max on the app will mean the volume coefficient is 1.0000000... so it will return the original data.
Rob
Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
post-12274242
Post #9,717 of 40,299
NaiveSound
Rob
I've been feeding my beloved mojo from A dx80 (it's a dap) via coaxial, but I've always had the dx80 volume on 0 and only controlled the volume on my mojo.
When I use my android note 5 I have to have the volume midway and still control volume with mojo, should I turn both dx80 and note 5 volume on max and then also control volume on mojo?
What is the best way, for the best possible sound. For both the Dx80 and note 5
post-12274269
Post #9,718 of 40,299
lurk
Rob
Very good info tht should be added to FAQ!
Volume control on mojo, other volume should be maxed out.
I wanted to ask a similar question but for the Hugo instead. Can I assume same settings applies?
Thanks Rob/Chord
post-12274270
Post #9,719 of 40,299
EllieFreckles
Totally new here. But I'm absolutely amazed by this device. Barely just heard about it, and it's so impressive to me given its size and what it does. As well as what other people are saying about the quality. This is on my list of what I am considering getting next.
post-12274275
Post #9,720 of 40,299
x RELIC x
Given that you still hear music with the dx80 volume at zero then it would be bypassing the volume control completely (like most DAP's digital output). No need to adjust the volume on the dx80 I believe. As per Rob's post above, if you can adjust the volume on digital output then you should maximize it.
Users Who Are Viewing This Thread (Users: 1, Guests: 14)
  • Top
