Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12272539
Post #9,661 of 40,464
Angular Mo
A warning to all who crave all that detail and do it with volume.
I hurt my ears doing so, with the Mojo and DT 990-33 and am now suffering horrible tinnitus; a high frequency uninterrupted tone in my head.
There is no escape from the suffering,
post-12272632
Post #9,663 of 40,464
Ra97oR
CanJam London 2016 Karting Champion
That holds true to any audio playback system. Value your hearing make sure it is within reasonable limits, hopefully your tinnitus will go away with some rest.
Reactions: Angular Mo
post-12272652
Post #9,664 of 40,464
CareyPrice31
Montreal Canadiens
Where can I buy one of those extremely low profile optical plugs from ak100 to mojo?
post-12272730
Post #9,667 of 40,464
mscott58
That looks like it is hurting both jacks.
are you sure, you should not had made it a little longer?
George - The bend are molded into the cable, so it stays that same shape even when it's not plugged into anything. That's actually part of Sys Concepts art is putting bends into optical cables! And they do it well. Cheers
post-12272760
Post #9,668 of 40,464
ElMariachi
Oregon Coast
Oregon Coast
comparing this with my dacport lx, the sound from mojo is....more exciting.
with non-audiophile terms, with dacport lx it is like you are playing from a record, while from mojo it feels like you are watching it live! like 2D vs 3D! very obvious after a few songs.
from my hd700, with dacport lx things are good, revealing, instrument separation etc, but once i plug in the mojo, after a few songs i can feel that dacport lx is more boring/recording like while mojo is really exciting. it is not V shaped because the mid/voice is good, so i agree when people here commented about W shaped. The bass is better, the treble is better, everything is more 3D.
no bad treble in case you wonder about hd700.
songs that immediately struck me about the 2D vs 3D is 'All out of love' by Olivia Ong. The guitar and the vocal.
disappointment? android spotify doesnt support OTG yet. and window 7 drivers is a pain at first without the digital signature.( dont bother about skipping the checking of signature, wasted an hour)  so by following some online guide i use dseo13b.exe from schoolome tech website to sign the digital signature.
Hi, just read this post from a month ago. Do you plug your hd700 directly into the dacport lx or is it going into an external amp?
post-12272766
Post #9,669 of 40,464
NaiveSound
Do tell us what you think is awful about the dx80 and how does it compare in SQ to the Mojo.
Guys, do any of the cheaper Samsung smartphones for example work as a digital source with the Mojo?
Do the phones need to have some special OTG output/function and if so is this option/ability only found in the higher end smartphones?
I was thinking of the Samsung Galaxy Grand Prime for example.
I am sure a lot of people would like to know the answer to this question or perhaps it has already been covered on this thread.
I wonder if this dude forgot his Mojo. :blink:
Pops, clicks, cracks, thuds, and painful noise every time you go to the next song, FW is flawed, it's just poop, I'm selling it and trying to find a small compact Cheap smartphone to feed my mojo
post-12272782
Post #9,670 of 40,464
yoyorast10
that's the problem with most daps. You'll be much happier with a smartphone tbh
post-12272964
Post #9,671 of 40,464
Ike1985
Wow man, audio is sort of like the boiling frog story, you don't realize how loud you're listening if you keep cranking. I had a similar experience when a double barrel shotgun was fired several feet from me and I didn't have protection on. It'll go away eventually.
Right now I listen to probably 20-30 metal al ins a day on YouTube, I always start with volume off on mojo and gradually come up as albums differ in volume. It's also the reason I bought the ADEL CIEMs from 4 audio which make lower volumes seem louder. Best of luck, hope you didn't do any permanent damage.
Mojo makes it extremely tempting to keep cranking since it's so insanely resolute.
post-12272986
Post #9,672 of 40,464
San Man
  Anything more low profile?
Not that I've seen.   Either the sysconcepts or moonaudio cable rise up about the same height from the appropriate jacks.
post-12273002
Post #9,673 of 40,464
mathi8vadhanan
They were working on this prototype. You can ask them about this.
  If you want a close fit, here is a an optical from Sys concept they are working on. The optical cable is epoxied into place but you can never pull on the cable to remove it.  You have to remove the toslink a little and then the mini end and back and forth and keep the Mojo and whatever source you are using, stable but it works well and is almost like having no connection as there is little protrusion.
post-12273020
Post #9,674 of 40,464
kikouyou
post-12273026
Post #9,675 of 40,464
masterpfa
Anyone run their mojo with a small smartphone? I'm thinking about selling the aweful dx80 and buying a small smartphone to run mojo with exclusively. Any smartphone thst pairs up good size wise?
Motorola Moto E 2nd gen or Moto G 3rd gen are other options especially if available cheaply where you are
As above or any of the more recent budget phones Huawei, Xiaomi and Asus, Wiley Fox, OnePlus X
Users Who Are Viewing This Thread (Users: 4, Guests: 7)
