Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Jan 13, 2016 at 5:05 PM Post #9,212 of 42,759
Has anyone found a good portable cable solution for type C to micro yet?
I got the Fusion4K cable off amazon for my Nexus 6P since it was the shortest length at 1ft (which is still too long) and the connectors bent due to a soft plastic housing. Looking for a replacement now.
Also, did we determine if ferrite cores are the solution to eliminating RF noise. Kinda annoying to be driving and hear that snap crackle pop lol.
Jan 13, 2016 at 5:29 PM Post #9,213 of 42,759
You mean like this?
Jan 13, 2016 at 6:47 PM Post #9,216 of 42,759
So. Tell me. Is the improvement that the Mojo makes to the iPhone 6S such that I would appreciate it on the move, on public transport, or is it something that I would only really appreciate at home listening properly?
Jan 13, 2016 at 6:52 PM Post #9,217 of 42,759
  5:45 is this normal charging time? (2A)
That's still well under the 10hrs in the instructions.
Sure, some find 4 hrs is enough, but I wouldn't worry at this stage, just because you're at 5:45 without completion
Relax; pull up a chair; make a nice playlist for when you fire-up your Mojo!
Jan 13, 2016 at 7:30 PM Post #9,218 of 42,759
Kris - With K10's it's good anytime, anywhere! Cheers
Jan 13, 2016 at 7:33 PM Post #9,219 of 42,759
Thanks @Mimouille. I think your stack looks awesome with the bumper and 3M so I might as well order it and not worry about the leather case. I prefer your clean lines to my ugly band.
If you are worried about the leather case, you can put a protective plastic film on the back of  the leather and stick the 3M to that.
Jan 13, 2016 at 9:34 PM Post #9,221 of 42,759
  You can still use the 3M on  your case, rather than AK's body.
Nice case,
One question does the 3M leave any residue, my only concern and reluctance so far to use on my AK100 Mojo combo.
EDIT: just seen @Mimouille reply above (unless there are any other ideas)
Jan 13, 2016 at 9:42 PM Post #9,222 of 42,759
Nice case,
It comes off easily (without any residue) from AK's case compared to Mojo's surface. I had to remove the stack after 2 months of use, to RMA the Mojo.
Jan 13, 2016 at 9:43 PM Post #9,223 of 42,759
Did you have the indoor or outdoor Dual Lock?
Jan 13, 2016 at 9:45 PM Post #9,224 of 42,759
Jan 13, 2016 at 9:52 PM Post #9,225 of 42,759
