Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
604 605 606 607 608 609 610 611 612 613
615 616 617 618 619 620 621 622 623 624
  1. CareyPrice31
    What optical cable is that?
    And what model of the AK100 is it?
  2. alan_g
    its a sysconcept
  3. CareyPrice31
    Link?
  4. alan_g
    http://www.sysconcept.ca/product_info.php?products_id=349&osCsid=t4705tl3v8arbs95uqutfgjjf1
  5. shotgunshane Contributor
    Or go naked.
  6. CareyPrice31
    Thanks - what options/config do I select?
  7. John Culter
    As DAC there is 2x Cirrus Logic CS4398 (same as for AK240) in DX80 .. What kind of difference brings Mojo in the game? :)
  8. alan_g
    i think it shows you how to measure what length you need but i suppose its all down to where your daps ports are.
  9. CareyPrice31
    I want to do AK100 to Chord Mojo like you have - what do I need for this?
  10. NaiveSound
    I like mojo better than dx80 (whatever dac it may have) it makes sound more musical, it does warm it up some, I gets rid of all hiss (se846 is sensitive) an makes the sound overall much better, to me, and clearly many others.
    I think sound could be better but the lack of *wow* may be due to my mediocre iems (se846)
  11. John Culter
    Sure! Not complaining about the Mojo :wink: I was just considering the DX80 as standalone device, but this means DX80 is not as good I will keep using iPhone with Mojo :wink:
    Perhaps this can be also something to do withthe different AMPs in both devices and not DAC itself.
  12. San Man
    Exactly as pictured is 2.2cm length, 5mm jacket insulation and 90* bends
  13. NaiveSound
    Stick with iPhone + mojo
    Maybe the dx200 which should be awsome, will actually hopefully will be better then mojo
  14. faran
    Yup mine is exactly that. I went for the thicker cable as I thought it would be more durable during my travels.
    The DAP is the original AK100 with the Red Wine Audio mod.
    I just had a nightmare situation as I rushed out the office to get back for the Arsenal v Liverpool game and attempted to put in my Spiral Ear SE-5s as the right piece fell on the street in the dark. I spent ten minutes looking for it but just couldn't see it anywhere with the "torch" on my iPhone until finally the gods smiled on me. And Arsenal have just equalised so I'm elated! Apologies for going off-topic.
  15. mathi8vadhanan
    You can still use the 3M on  your case, rather than AK's body.
